Pinarello F12 Rim brake build
Boshk
by Boshk
Pinarello F12 Rim brake size 50 Team Ineos build
Haven't quite figured out what I want yet, but here are some photos and more importantly, weights of some of the components and frame.
Advertised weight is 820g, thats unpainted and as you will see, when its painted in Team Ineos colours, its close to 992g.
Boshk
by Boshk
Presentation wise, standard cardboard shipping box, some form inside to protect the frame and just 2 plastic bags with all the required accessories.
Compared to my Colnago C60, pretty slack.
Italian thread bb
Seatpost weight....221g
The clamp weight is 57grams
Stem/fork cap
Headset pieces
Boshk
by Boshk
Frame weight without headset bearings 992g
headset bearing weight 31g each (two)
Fork uncut weight with expander 466g
Boshk
by Boshk
frame with and without upper headset bearing
uncut fork
mechanical cabling adapter
Attempt to route brake cable (campagnolo Ultra shift rear brake housing)
rear brake cable exit
rear derailleur internal cable route.....had to sand the hole slightly to remove paint so that the metal grommet could fit
DaveChow
by DaveChow
Beautiful frame. Can't wait to see your complete build!
Sent from my LM-V405 using Tapatalk
jobvisser
by jobvisser
Nice build man! I always like the style of Pinarellos. Is it true that the steerer tube it 1 1 1/8 at the top but the bearing is a 1 1/2 sized one ?
Boshk
by Boshk
DaveChow wrote:
Sun Oct 27, 2019 9:15 am
thanks, haven't had time to build it yet, will get photos up when I do
Boshk
by Boshk
jobvisser wrote:
Sun Oct 27, 2019 12:28 pm
Yes I believe that is correct. Convectional fork tube diameter 1 1/8.
Both the upper and lower bearings are the same, 31g each with the follow printed:
OD:52 x ID:40 x H:7 x A:45°
this metal plate is the 1st piece before the Most 'shaped' cover
welchy
by welchy
Enjoying some true weightweenieing with all the scale action. Looks like this'll build up to be a bit of a stunner, any idea on end build weight goal?
zappafile123
by zappafile123
I am gobsmacked that some of the parts are *SO* heavy. WTF... 221 g for a seatpost... 466(!!!!) g for a rim-brake fork... 100g for all the headset parts. Crikey. Getting it below 7kg with a power meter and deep dish clinchers would be impossible. So it's like 1720g for the frame, fork (cut), seatpost and headset?
Did you use brake housing all the way through the frame for the rear brake?
Anyway, I'd love to hear a ride report when it's all built. I'm sure it will be a fantastic riding bike.
Enigma Elite HSS| Spesh Tarmac SL6|Colnago C60|De Rosa Protos|Bianchi Oltre XR4&XR2|BMC SLR01 16|Cannondale Evo HM 12|Focus Izalco Max| Ridley Helium SL|Basso Diamante 15|Scapin Dyseys S8|Time ZXRS|Giant TCR SL 12| Ridley Noah 08|Look 585|Cervelo SLC
Boshk
by Boshk
zappafile123 wrote:
Wed Oct 30, 2019 11:14 pm
Yea I know, its beautifully made and painted, once I get the fork cut etc, I'll let you know but I think it will be a little while.
In regards to your rear brake cable going through the top tube, I have, which would increase the weight that tiny bit more. The 2 holes front and rear are the size of the housing, I cant think of anyway to mitigate the housing through the top tube.
Thinking of replacing:
Headset bearings
Expander which I haven't weigh yet
lightweight skewers
Berks saddle clamp
tabl10s
by tabl10s
Boshk wrote:
Thu Oct 31, 2019 12:09 pm
Headset bearings
lightweight skewers
Berks saddle clamp
The Berk clamp is no longer available.
2015 Pinarello F8: 13.05lbs/5.915kg
2016 Rca: 11.07lbs/5.048kg
2018 Rca
2018 S-Works SL6 Ultralight: 12.03lbs
survivor
by survivor
tabl10s wrote:
Sun Nov 03, 2019 8:49 am
I got one recently from Berk for my F8 although it has been taken off Berk's website. Just email Berk to see whether he still has any clamp inventory left to sell you.
fogman
by fogman
I have a Berk clamp on my F10. Why is it no longer being sold? Hopefully not a safety issue.
It's all downhill from here, except for the uphills.
tabl10s
by tabl10s
fogman wrote:
Wed Nov 06, 2019 2:33 am
As long as you have a Pinarello, I'd keep that clamp.
2018 Rca
