Kayrehn's Factor VAM disc build
Update of incoming parts -
Sram HRD levers and calipers - only found 3 online retailers selling them, most stock only AXS now
Ashima Aineon rotors, J&L thru-axles and titanium rotor bolts set - from ebay
Sram Red Gxp cranks - new from eBay, in case the BB30 cranks can't go on the frame.
And now I'm left with the wheel build. To use Berd spokes, I'll have to use Carbon-ti X-Hub SP for the front and stick with Extralite HyperRear 2 for the rear hub. Can anyone offer a review of the Farsport 25mm rims? My wheelbuilder is advising against it based on a perceived lack of strength. I don't know how much stronger a 30mm rims can be over a 25mm rim
- wheelsONfire
Why don't you buy something like Schmolke or Bikebeat?Kayrehn wrote: ↑Wed Oct 09, 2019 1:30 pmUpdate of incoming parts -
Bikes:
Open *UP* (2016.04.14)
I've never heard of bikebeat, thanks for pointing them out to me. It's still best to build light wheels from preferred parts, due to my past experience with my previous wheels. Almost all light wheels uses ti/light alloy spokes (which fatigue quickly - my ti spokes started breaking at 2000km), extralite road hubs (which doesn't have good drive/NDS tension ratio) and internal nipples (which makes it a pain to true with tubular wheels), all which are not ideal. Hence my current plan for using Berd spokes still (I believe they are indestructible for cycling usage), extralite mtb hubs (with good tension ratio) and rims with external nipples.
- wheelsONfire
Schmolke, Tune, Bikebeat and more uses same braded rims but with a minor difference in ext/int width.Kayrehn wrote: ↑Thu Oct 10, 2019 5:20 amI've never heard of bikebeat, thanks for pointing them out to me. It's still best to build light wheels from preferred parts, due to my past experience with my previous wheels. Almost all light wheels uses ti/light alloy spokes (which fatigue quickly - my ti spokes started breaking at 2000km), extralite road hubs (which doesn't have good drive/NDS tension ratio) and internal nipples (which makes it a pain to true with tubular wheels), all which are not ideal. Hence my current plan for using Berd spokes still (I believe they are indestructible for cycling usage), extralite mtb hubs (with good tension ratio) and rims with external nipples.
So, a braided rim is supposedly more impact resistant. I have no idea of Berd spokes, but i have seen them.
How about keeping tension on those?
Bikes:
I would steer clear of FSE rims, i had my wheelset for 6 months and by chance noticed a section of the braking areas had delaminated. After much comms with FSE they have decided to basically ignore all my comms....
Yes, from experience i would try to avoid this combination!
Looking forward to this build! "Imaking"s Factor looks absolutely amazing!
It landed yesterday!
16g over claimed weight but there are the port covers on and a solid strip of chainstay protector etc so that's fine.
This is real good!
J&L thru-axles coming seatpost binder
Headset bearings
Gonna slam the stem so this is the only one needed.
This is real good!
Headset bearings
The parts going onto it
-5g for 2 extra screws added onto the scale
Wow, That Berk combo looks much more comfortable than mine, but 18g heavier
/jonas l
http://instagram.com/jonaslundb
This is an old photo actually, gonna transfer them from my Fuji bike over to the new build. I recently saw someone here (one of the admin I think) selling 2 pairs!KCookie wrote:Where did you get the xpesso 15 peddles from please. Mine need replacing and can't find any anywhere. Cheers.
Awesome, thanks will take a look.Kayrehn wrote:This is an old photo actually, gonna transfer them from my Fuji bike over to the new build. I recently saw someone here (one of the admin I think) selling 2 pairs!KCookie wrote:Where did you get the xpesso 15 peddles from please. Mine need replacing and can't find any anywhere. Cheers.
Sent from my SM-G960F using Tapatalk
Wow this build is going to be nice. I’m looking forward to seeing how light you can make it. You are off to a really good start with that frame weight and all the parts so far. With some Berd wheels you will definitely be lower than the Fairwheel Bikes build done some time ago.
BH Ultralight
Litespeed Ghisallo
Scott Addict Singlespeed
Cannondale Evo HiMod
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
Thanks for popping by Godzuki26, nothing very much custom or exciting compared to your project heh. I haven't got round to doing a weight estimation yet. I took a look at madcow's build list and it seems like a toss-up - he has lighter cranks and saddle-post unit but I have a lighter cockpit and frame. Farsport 25mm wheels at claimed 250g each were ordered 2 days ago (They said they will weight it to ensure it's within acceptable range before shipping) but they will be paired up with MTB disc hubs so that'll add more weight compared with usual road hubs.
I am going to get fluoro yellow custom decals over all the blacked out logos and black decals over the red stripes, don't really like the subtle red accents and am not a fan of the stealth look. Am thinking of getting matching Carbon-Ti hubs in acid-green to go, will it be excessive?
I was wondering what your color scheme was gong to be. I really like that Carbon Ti hub! You should do it!!! Don't be boring and get black like everyone else If you are getting Black Berd Spokes and carbon rims those hubs will pop nice like this.....
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
