Pinarello Dogma F12 Super Record EPS 12 2020
anquetil
by anquetil
[imghttps://s6.mojalbum.com/10007766_17379334_24664095/kolesa/24664095.jpg][/img]
anquetil
by anquetil
7,38 kg
DaveChow
by DaveChow
Stunning build!
Full Italian components very well match in this setup. The colour is unique as well.
What tyre width you are using?
Sent from my LM-V405 using Tapatalk
anquetil
by anquetil
Hi
Thanks!
25 Vittoria Corsa Graphene 2.0
DaveChow
by DaveChow
Nice, this ends up at 7.38kg is not bad.
Is this a tubeless setup?
How's the ride quality of the new Dogma?
Frankie13
by Frankie13
Looks stunning ! How tall are you and what size frame is this? It does look perfectly sized.
mike
Resident Pro
by mike
:popcorn:
Noctiluxx
by Noctiluxx
Looks beautiful. The only thing I would have done differently is to have gone with WTO wheels instead.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
anquetil
by anquetil
Frankie13 wrote:
Fri Aug 30, 2019 3:54 pm
Im 174 cm, inseam 80/saddle hight 69cm frame size 50, stem lenght 100, handlebar width 38
No tubless/dont trust to much tubeless riding with latex tubes
Riding nothing special, same like with similar bikes from other brands.
Must notice: Campagnolo disc brakes are muuuuuuch better than Shimano Dura Ace, other components on same level like DA.
About wheelset, waiting for LW - tubular
DaveChow
by DaveChow
In what way Campy disc is better than Shimano DA? I am also having dilemma btw the two. Can you shed some lights based on your experience.
romanmoser
by romanmoser
Riding now ultegra di2 levers ( same as dura ace , except 30gr heavier )
I would say that the campy ones offer the advantage of ajustable braking feeling
YOu don't have that with shim
Also heard , that they were more silent under rainy , wet conditions
and also magnetic retractable pads or pistons
sometimes a piston takes more time to get back in with shimano
anquetil
by anquetil
DaveChow wrote:
Sat Aug 31, 2019 2:32 pm
Much more stronger, softer filling, no blink blink two or three times after long braking, better and more ergonomic levers.
1sanglier
by 1sanglier
Hi,
Do you have a GPS Support ? Which one ?
Thanks
anquetil
by anquetil
No GPS support, no need at all.
topt
by topt
what is the tyre clearance on the f12, can you ride a 30mm width rim ?
thanks
