S-WORKS Venge 2020 - Size 58
Miles253
by Miles253
So new bike day is very nearly here. I just need to build the thing!
I've just received my brand new 2020 S-Work Venge and have a fairly complete build list which I'll put below.
The only really question mark is which handlebar to go for as the Specialized Aerofly ii is out of stock until at least October in my size. Are there any other options that will allow for fully internal routing? Preferably with a shorter reach than the Aerofly as well. Let me know.
Anyway, looks to be heading towards 8kg which isn't too bad. Some room for improvement though, suggestions welcome.
Thanks
Sent from my EVA-L09 using Tapatalk
Specialized S-Works Venge | in progress
Rose Backroad | 9kg
Canyon Ultimate CF SL | 7.5kg
https://www.findyourroad.co.uk/
Instagram: @miles_bc
Miles253
by Miles253
Oops forgot the build list!Image
Rose Backroad | 9kg
Imaking20
by Imaking20
LOVE that color. A bit jealous.
My handlebar recommendation would be Pro Vibe Aero. I've run one for a few thousand miles and I've loved it. Building up an S-bike myself though so I'll be going Aerofly II.
Current:
Acid Minty
Retired:
Wilier Wonka | The Dentist | The Bucket List | Specialissima | Evo | T2 | Blue | Project C6.0 | Felt AR FRD | Colnago C59 | S-Works Tarmac SL4| S-Works Venge | Wilier Cento1 SL | Tarmac SL2
integration
by integration
Very nice! Pro vibe aero incl. Superlight version is a great alternative
Miles253
by Miles253
integration wrote:
Thu Aug 29, 2019 3:59 am
Will the Pro-Vibe allow for fully hidden cables up front? Cheers for the recommendations!
Rose Backroad | 9kg
Miles253
by Miles253
Pieces are pretty much all in now! Excluding the bar...
Looking at building it up with an alloy bar and swapping later...ImageImageImageImageImageImageImageImageImageImageImageImageImageImage
Rose Backroad | 9kg
Lucendi
by Lucendi
Super nice frame!
Imaking20
by Imaking20
Is your garmin mount broken?
Current:
Acid Minty
Retired:
Miles253
by Miles253
Imaking20 wrote:
Sat Sep 14, 2019 4:11 pm
Not that I noticed! Probably ought to check that!
Rose Backroad | 9kg
Miles253
by Miles253
Not broken, just without the mount fitted.
Rose Backroad | 9kg
Miles253
by Miles253
The build is FINALLY finished. I had huge trouble getting a hold of the Aerofly ii bars which delayed things a bit...
But still, here she is. Will post a full build list below. Image
Rose Backroad | 9kg
Miles253
by Miles253
Build listImage
Rose Backroad | 9kg
ajcav86
by ajcav86
Frame size ? Also frame and fork weight individually?
mf22433
by mf22433
ajcav86 wrote:
Fri Jan 10, 2020 5:26 pm
The size is in the title: size 58
ajcav86
by ajcav86
Very unobservant! I do apologise.. in that case even more keen to know the weight of the frame with out the fork, and also if anyone has a competing 58 weight for a black one... planning to pull the trigger in the summer on one and it needs to pull double duty as a rolling course TT rig and a mountain goat rig with enve 7.8s and roval Terra clx's
