Colnago C64 Mapei 48s (rebuild with SR12 EPS)
Hmmmm. It sounds like your front rim was laced backwards at the Campagnolo factory. I would flip it as I believe the bearings are designed to roll in one direction. Perhaps the AC3 grooves are just cosmetic. The Campagnolo WTO manual states: “The braking rim is micro-engraved to prevent forgeries, but these elements will gradually disappear as the wheel is used. Braking effectiveness and wheel operation are not affected by the disappearance of the micro-engraving on the braking rim.”
I have 4 different Campagnolo wheelsets (Shamal Ultra, Bora One 35 Clincher, Bora One 50 Tubular, and Bora WTO 33). On all 4 sets the bearing preload adjuster is on the non-drive side for both front and rear.
It's all downhill from here, except for the uphills.
Correct. And you should be able to read the 'usb' of the front hub, i mean facing you when on the bike.
- Contact:
This is the funniest thing I've read in a long time... hahahaha
Correctfogman wrote: ↑Mon Jun 22, 2020 3:26 amHmmmm. It sounds like your front rim was laced backwards at the Campagnolo factory.
lol whats up Rich .. Happy Father's Day !CrankAddictsRich wrote: ↑Mon Jun 22, 2020 12:59 pmThis is the funniest thing I've read in a long time... hahahaha
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2023 Colnago G3X-SRAM AXS Force-Levante
to be honest I've had the bora one 50 and 35 with 24mm width rim and before the ac3 brakeing from my previous colnago but I never really pay much attention when I installed my front skewers wether the preload is on the nds. both of them have been sold already though. Although I saw a post by GUYC when he got his WTO and had the same look as my front warning sticker on the ds. I'll probably leave it as it is .. I already put 150 miles with no problem so far.fogman wrote: ↑Mon Jun 22, 2020 3:26 amHmmmm. It sounds like your front rim was laced backwards at the Campagnolo factory. I would flip it as I believe the bearings are designed to roll in one direction. Perhaps the AC3 grooves are just cosmetic. The Campagnolo WTO manual states: “The braking rim is micro-engraved to prevent forgeries, but these elements will gradually disappear as the wheel is used. Braking effectiveness and wheel operation are not affected by the disappearance of the micro-engraving on the braking rim.”
nice another build ! sure but i'm not much an experience on Cipo I've had the RB800 and kind a miss that bike too.Seedster wrote: ↑Mon Jun 22, 2020 12:35 amgood to hear. I have a pair of WTOs, only 45mm, sitting in the closet waiting for a stelbel Ti9 frameset. I need to PM you about your thoughts on Cipollini....
Yeah, and make sure you install the right-hand bearings on the right side, unless you are cycling in countries like the UK where the bearings should be switched to the other side.CrankAddictsRich wrote: ↑Mon Jun 22, 2020 12:59 pmThis is the funniest thing I've read in a long time... hahahaha
Sorry for hijacking this thread. Bearings aren't directional, but fogman was partially right. On campagnolo/fulcrum wheels, bearing preload adjuster should be on the NDS. As for the ac3, you should follow the arc grooves like arrows so directional.
Like any other wheel/hub brand, the proper way to put a front is you can read the brand or be facing you when on the bike. The front and rear wheel/hub uniform.
Sorry for the misinformation. I made the incorrect assumption that the bearings were directional due to the bearing preload adjuster being on the NDS on all my Campagnolo wheels (e.g. on the NDS the direction the wheel rotates is opposite the direction the bearing preload adjuster tightens).
Ok look at the 3rd picture on this probikekit wto look closely at the ac3 grooves which is the correct direction and look at the preload its on the ds. Maybe the sticker was put wrong?
https://www.probikekit.com/bicycle-whee ... n=12138273
Rule of thumb. You can't place the rear wheel backwards so just follow the rim/hub direction of the rear
Cool and thats what on the picture !ome rodriguez wrote: ↑Tue Jun 23, 2020 4:17 amRule of thumb. You can't place the rear wheel backwards so just follow the rim/hub direction of the rear
@nismosr. Your Colnago C64 is beautiful and a very similar build as my own. Maybe my front wheel is the one that is backwards. I was thinking your thread got somewhat hijacked and maybe this discussion would be more appropriate in the Bora WTO thread instead.
