2020 BMC Roadmachine 01
dacrazy1
by dacrazy1
BMC started a recall for the discbrake-forks today; SL01
https://ch-de.bmc-switzerland.com/recal ... re=intl_de
TuplaO
by TuplaO
Nice build. I've had the 01 THREE for a month or two now. It's both rock solid and super smooth. Some random points:
The OEM bar tape is great
I also thought about Arundel cages, but my LBS built the bike with Elite Vico Carbons, which have definitely exceeded my expectations. Nice to see an RM specced with Arundels, though.
The bike came with tubeless DT wheels, but shod with non-tubeless Vittorias/inner tubes, which I thought was a bit weird at this price point. Already replaced them with 28mm Hutchinson Sectors I had lying around. Apparently only the top specced RM comes with tubeless tires.
I will end up slamming the stem. The highest setting would be waaaay too high for me. However, for those needing a (very) relaxed position, this is the good news.
The integrated computer mount is a Garmin version, which requires Wahoo users to buy the frankly ridiculously priced adapter.
Spez
by Spez
Thx,
My LBS used a Shapeways Wahoo Elemnt BMC mount, works great
Arundels are on my 4th bike now, can’t destroy ‘m it seems.
jasonh
by jasonh
Definitely one of the bikes highest on my “want list”. Definitely looks better with Boras
Arundel everything works well. Even their bar tape is really good
Canadian
by Canadian
Spez wrote:
Sat Aug 17, 2019 7:51 am
Hi,
Not many pictures of the 2020 model on the web yet, so thought i’d share my new build.
2020 BMC RM 01 54 module build up with full DI2 9170, Roval CL64 wheels, Assioma Duo powerpedals, Arundel cages, Fizik Antares R1, BMC stem 110, 42 roadbar & Wahoo mount. Tires are Corsa G+ Control 25.
Weight is 7,9kg as shown.
Sent my iPhone with Tapatalk
Very nice! Can I ask what headset spacer you have? Is that the "low cone" with two spacers? or the "high cone"?
Thanks,
Chris
FLO Cycling: http://www.flocycling.com
FLO Blog: http://bit.ly/b3Zlpq | FLO Facebook: http://bit.ly/d8KDhI
TuplaO
by TuplaO
Looks like the low cone to me. I have a similar setup for now. This will change, however, as the position isn't that low in actual fact.
Spez
by Spez
TuplaO wrote:Looks like the low cone to me. I have a similar setup for now. This will change, however, as the position isn't that low in actual fact.
That’s correctImage
FTPWhor
by FTPWhor
Does the module come with bar tape??
Tibber67
by Tibber67
Having just received my 2020 module, I can attest that it does not come with tape
