2012 Cervélo R3 Team project 5384g
Moderators: MrCurrieinahurry, Moderator Team
Lucendi
by Lucendi
An Extralite stem (120mm -12°) came in at 89 grams, the Zipp SL Sprint came in at 168 grams. A total of 79 grams saved there! :)
I'm waiting for an Mcfk handlebar (176 grams), a lightweight PYC chain (231 grams) and some J&L titanium quick release skewers (36 grams). Then the bike will weigh 6600 grams!
burglarboycie
by burglarboycie
That’s the stem I want, length and drop perfect!
Lucendi
by Lucendi
burglarboycie wrote:
Wed Sep 18, 2019 8:55 pm
Thanks! - I like how there is a space (although tiny) between the steerer tube and the handlebar drops when viewed from the side. :)
Lucendi
by Lucendi
I decided to go a bit more extreme with the weight saving and have started to remove the paintjob on the frame;
I'm about 4 hrs in to what I expect to be a 20 hr job.
jch3n
by jch3n
Seems like you should probably dismantle the bike at this point to do the paint stripping properly...
Gary71
by Gary71
it looks like he is still using it while stripping - which I think is hilarious !
love it. :lol:
Lucendi
by Lucendi
All done, I lost 156 grams removing the paintwork.
Gary71
by Gary71
I like it.
Are you going to put the the logos back on or leave it as a plain Jane?
Lucendi
by Lucendi
Gary71 wrote:
Sat Sep 21, 2019 11:51 pm
I like it.
I don't know if vinyl decals would look very good or last very long. I think I'll paint something on using water based acrylic paint (I can always scrape it off if I get tired of it).
Lucendi
by Lucendi
An Mcfk compact handlebar saved 17 grams over the Zipp Ergo-70;
AZR3
by AZR3
Very nice :thumbup:
Lucendi
by Lucendi
AZR3 wrote:
Sat Sep 28, 2019 1:44 pm
Very nice :thumbup:
Thank you! :)
Lucendi
by Lucendi
Some J&L titanium skewers coming in at 38 grams saved 33 grams over the Zipps;
I used 303 Aerospace Protectant as suggested by member jorisee01;
It gave the frame a clean glossy finish which looks great!;
Lucendi
by Lucendi
Here's a quick update on the project.
The bike has now recieved some skeletonized shifters from fellow WW-member 4ibanez's old build. The modifications of the shifters saved around 30 grams;
Also some Lightweight Standard Gen 2 tubulars has been fitted saving a couple of hundred grams. The wheels weigh significantly more than they ought to so I believe there is a lot of old sealant in the tubes;
Currently it weighs in at roughly 6,2 kgs.
Nixster
by Nixster
Looks great!
What sort of tyre clearance are you getting on this frame?
I see you’re running tubulars so are those 25mm? And how much space to the frame?
I seem to think 23mm is the max but hope I’m wrong, seen one on eBay in my size!
Thanks!
