Fuji SL aimed for sub 6kg...got 5.5kg & 6.01kg with everyday wheels
Moderators: MrCurrieinahurry, Moderator Team
Squashednuts
by Squashednuts
Just 10 bloody grams to go for sub 6kg with every day Wheels
Swapped rear inner tube for latex and save 30g ish
New crank, rings and BB saved 180g
Building Spec Allez
Sold
Fuji SL 5.5kg viewtopic.php?f=10&t=157704
Sold -
Izalco Max Disc 6.7kg http://weightweenies.starbike.com/forum ... o+Max+disc
dereksmalls
by dereksmalls
Glad I could help drop a massive amount of weight for you!!
Looks great!
Squashednuts
by Squashednuts
dereksmalls wrote:
Sat Oct 19, 2019 7:59 pm
200g was an exaggeration more like 181g :D
Still pretty good bang for my buck :thumbup:
Wouldn’t have bought a new crank or gone the THM route...bit too pricey
Crank was 350g, photo is 360g but there are 10g of spacers
Rings were 94g and 35g
Bb was 80g
Total 559
sram red GXP weighed 595g
BB C-Bear 145g
740g
Building Spec Allez
Sold
Sold -
mlee6050
by mlee6050
Thanks for showing yours, tempting to do mine
My one has a lot of bits lighter but seeing yours I can get mine to 5.9kg if money was no object, I spent like bit more than £3500 (all new parts) note I have disc brakes so according to gcn if rim it be 5.5kg as disc adds 400g
Compare ours, if chose what you got:
Chain save 23g
Crankset save 128g (but I got a powermeter and bb30 so unsure what cogs save)
Seatpost save 16g
Stem save 59g (but I use 130mm)
Saddle I replacing 126g (claim 120g) to a claim 88g saddle
Frame unless you can help me with?, I save 541g if can get sub 1kg (combine fork and frame, I use 56cm) only ones I can find are over £4k and I look for normal even though I cycle over 20mph a lot as not like aero look
^ means I have to spend a guess £4,600-£4,800 more that not look to do unless current frame breaks
All rest I got light but compression heaiver as it keeps sliding no matter what
So you get to see list so far https://docs.google.com/spreadsheets/d/ ... 4bIBCb7lE4
Also it be updated when get saddle, tape wheels, and get new tyre weight
I know should use a new place but thought be nice to compare here and say thanks for showing yours
