Ryan Goes Offroad (2019 Cannondale SuperX)
FilmAt11
by FilmAt11
I had EggBeaters and XTR for a while, but have been much happier with TIME ATAC XC6 pedals - easy clip-in and solid pedals - I feel locked-in.
RyanH
by RyanH
Anyone know where to get a lower profile headset/compression cap for the SuperX? The headtube is beefy and significantly wider than a STS cover. I'd like to get something lower profile so I can run a -10 stem.
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
Gearjunkie
by Gearjunkie
Can you just use the low profile cap from an Evo?
RyanH
by RyanH
No, head tube is significantly wider.
Strava
DOUG
by DOUG
RyanH wrote:
Tue Apr 02, 2019 4:27 am
Pretty sure the Super X uses a 1-1/2" to 1-1/8" tapered steerer? You probably need the same low profile cap thats used on the Scalpel Si. The 1-1/2" to 1-1/8" Si to Tapered steerer adapter comes with one but havent seen them available for sale seperatly.
Whats the OD of that dome spacer? I can measure the OD of the cap on my Scalpel to confirm. I also have one of the adapters for my FSi monstercross build so can measure that one too but I'm fairly certain they will be the same.
CarlosFerreiro
by CarlosFerreiro
I think KP058 gets you the Cannondale low cap. 50mm dia.
I used the top set of a Cane Creek 40-Series ZS49 ZeroStack, at 49mm that's not bad.
kode54
by kode54
Those are some nice single track trails. I probably would ride those more than on the road. Deer would be the worst moving obstacle versus riding asphalt and dealing with cars in SoCal.
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
soupless
by soupless
@ryanh
Is that up off Runyon Canyon? I'm in the neighborhood and see the ribbons of dirt from Nichols all the time.
spdntrxi
by spdntrxi
kode54 wrote:
Tue Apr 02, 2019 2:58 pm
no kidding... I've have to take a pictures of my nearest "dirt" and it will become clear the changes I've made to my Gravel bike.
RyanH
by RyanH
soupless wrote:
Tue Apr 02, 2019 10:03 pm
@ryanh
Close, it's Fryman Canyon and Coldwater Canyon Park. I haven't explored anything directly off Nichols but it's about a mile from my place to the top of Multiview.
Strava
RyanH
by RyanH
It's 58mm wide, should one of the above work? Image
Strava
wrenegade
by wrenegade
I'm currently after the exact same thing for my '19 SuperX. I just bought this FSA Orbit Reducer Headset specifically for the top cap itself. I'm currently out of country but will update you this weekend when I'm back home and can try it out.
Alternatively, this is Stephen Hyde's SuperX headset/topcap: Image. I searched eBay for the same and was able to find it as part of a headset group, but just didn't want to pay more than double what I did for that FSA kit. We'll see if I have to go back and do that. It's a real shame that it seems impossible to find just the cap by itself.
CarlosFerreiro
by CarlosFerreiro
RyanH wrote:
Thu Apr 04, 2019 12:23 am
Yes, sorry I confused myself with the 49/50mm mention.
This one is the Cannondale KP058 and you can see comes with a low cover the same as the one on Steven Hydes bike.
https://www.cannondalespares.com/Cannon ... il/3-40287
This is the one I used, as the Cannondale was out of stock everywhere when I was looking. I just used the compression ring and cover from the Cane Creek in the stock bearing and it sits on fine but the outter diameter is about 1mm less than the Cannondale one would be. That covers all the essentials but leaves a small lip of the outer part of the carbon of the headtube uncovered. It's a finished surface so no big issue to me, but depending on how you want it to look...
49 on this one is the headtube inner dia, not the cover outer.
https://www.evanscycles.com/cane-creek- ... t-EV144427
DOUG
by DOUG
RyanH wrote:It's 58mm wide, should one of the above work? Image
Yep either way should work. Although the one for the Scalpel is carbon and covers the top of the steerer better than the one that comes with the KP205 headset.
Scalpel
FSi with KP205 headset installed
Unfortunately I havent seen the either bearing cover available seperately so you might be stuck buying the whole headset. Surely Cannondale in the US would be able to sort you out though? A good Cannondale dealer should be able to source the carbon cover seperately for you Im sure.
CarlosFerreiro
by CarlosFerreiro
~54.5mm outer dia on the Cane Creek cover.
