Godzuki26 thinks there needs to be a Weightweenie Scott Scale 900 SL build in the USA. With my Covid 19 paincave [pg 44]
Squashednuts
by Squashednuts
godzuki26 wrote:
Wed Nov 06, 2019 3:52 am
Thanks for posting the picture
I’ve read about people’s experiences with getting flats due to thorns and assumed they were like rose thorns
...these look weaponised...
Building Spec Allez
Sold
Fuji SL 5.5kg viewtopic.php?f=10&t=157704
Sold -
Izalco Max Disc 6.7kg http://weightweenies.starbike.com/forum ... o+Max+disc
Zac36100
by Zac36100
Godzuki, my advice for tubeless tape is tuo use HEAT RESISTANT TAPE.
It's very very thin so you need to overlap a couple of time the wheel. If I remember well, I did 2+1/2 turn
The adhesive power is good and the weight is excellent.
The cost is less than 5$
https://www.amazon.com/Temperature-Resi ... B00XH9Y7FU
Zac36100
by Zac36100
Squashednuts wrote:
Fri Nov 08, 2019 8:19 am
there is a nice story behind this cone connected with Giro d'Italia.
In the early stages in south Sardinia the peloton suffred a lot of puncture and everybody was thinking about a sabotage. Later, analyzing the punctured tubulars, they understand the real reason of puncture: the wind carried a lot of cone in the road
godzuki26
by godzuki26
I’m going to use the 3M Nuclear tape because it’s fancy and I like to be fancy. I should get it this weekend hopefully. The tires I ordered from R2Bike. I ended up getting Rocket Rons in 2.25 size. I also got some Racing Ray’s and Racing Ralph’s. I thought it would be cool to mix and match the front and the rear tires. For the first run, I will probably just go Rocket Ron for both front and back.
Since I’m trying something different with the rim tape, I thought I would use something other than Stan’s fluid. I ordered some effetto mariposa fluid. I remember hearing that it foams up and you don’t need to use as much as Stan’s. Has anybody tried this stuff?
:arrow: BH Ultralight
:arrow: Litespeed Ghisallo
ImageCannondale Evo HiMod
ImageFelt AR FRD
Slammed
by Slammed
The mariposa stuff works well. It's one of the only sealants that are approved for latex tubes so you see a lot of people putting it in tubulars.
jorisee01
by jorisee01
I use this and it works great. It foams when put in the tubular and has been good to me in relation to filling punctures.
Verstuurd vanaf mijn SM-G960F met Tapatalk
dereksmalls
by dereksmalls
jorisee01 wrote:
Sun Nov 10, 2019 9:52 pm
How much additional weight does it add to your tubular?
LewisK
by LewisK
Haven’t used this one, but I’ve always gone by a fraction under 1 to 1.
So 30ml of sealant will add roughly 25g.
Zac36100
by Zac36100
effetto Mariposa works well but I use the cheaper
https://www.ridewill.it/p/it/wag-567011 ... ro/140431/
It's very foamy and works well for 6months without leaking
I use 60ml in 2.2tire
without ammonia!!!
jorisee01
by jorisee01
I only use it when punctured. And I only ad 25 to 30ml
ryanw
by ryanw
Caffeelatex is shite IMHO.
It never managed to seal any of my punctures without a worm. Gone back to standard Orange Seal now. May work better at lower PSI. My 38c are around 45PSI.
Allez Sprint Disc - 7.60kg
SL7 S-Works - 6.73kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
godzuki26
by godzuki26
Carbon fiber rotors have been quite a failure for mountain bikes. But what about Graphene? I like the weight but will it be quiet and have the necessary stopping power for mountain bike applications? I am already past the “show bike” build stage and putting more heavier/durable parts on this build. So this Graphene Rotor is probably not going to happen 🙅‍♂️
ImageFelt AR FRD
dereksmalls
by dereksmalls
Ah just get them, trial them, then switch back if you have too.
Alexbn921
by Alexbn921
godzuki26 wrote:
Thu Nov 14, 2019 1:00 am
Not a real rotor that is usable in any way. :(
godzuki26
by godzuki26
Here are the weights of the Rocket Ron’s that I will run tubeless. This will be a 346 gram weight increase over the Maxxlite’s. Now I have some more realistic tires.
ImageFelt AR FRD
