Cervelo S3 Disc - New DA R9200 Rebuild + Pics + Build List (Page 7+8) - New Alps/Seatpost Weight 6.62 kg
- stevec1975
Just arrived, will be stripping it down where possible and weighing each part, am upgrading the groupset to Dura Ace and various other bits..
Full build list to follow..
S-Works SL8 - 6.19Kg/13.71Ib
Cervelo S3 Disc - 6.78Kg/14.94Ib
Scott Addict RC - 6.92Kg/15.25Ib
OnOne - Free Ranger - 8.68Kg/19.1Ib
Scott CR1 - 5.69Kg/12.54Ib
- stevec1975
First up, stock seating components:
SP20 Seatpost (211g all in):
Cradle, Bolts and Clamps (61.8g) - Will be sourcing a carbon cradle, shortening post and Ti Bolts (saving close to 25g)
Post clamp/wedge for frame (24.3g) - Can't really lighten this..
Prologo Dimension STN (267.4g) - Will be replaced by a Berk Lupina (saving close to 200g)
- Resident master of GIF
- Contact:
nice is the sp20 the same shape (interchangeable) with other seatposts as was the case with the sp15 and sp17 etc...
- stevec1975
@mjdwyer23: It came with R8000 Mechanical, but am swapping it out for Dura Ace 9100 Mechanical
@Nathanong87: I believe so, but not tried it, be good if someone like Berk made a lightweight replacement though, the head parts are super heavy.
@TiCass: I want to see if I can get it to around 7.4 Kilos (with Powermeter, Aero Wheels and Wahoo) - Going to be quite difficult!
I removed the stem spacers (all 41g of them!) last night to slam the stem (so that it mirrors the position within 5mm of my current bike), damn, it was a right pig to remove them, I also had to adjust the headset tension and stem bolt (which is hidden in a mass of cables halfway down the stem), I wouldn't like to do that out on the road.
Also, the RAT axles that Cervelo use weigh 128g a pair, any lightweight alternatives out there?
The Robert Axle Project
https://robertaxleproject.com/shop/ligh ... cification
- Contact:
yes i'm kinda suprised at the weight of the new style seatpost. But i'd be keen on getting a spare one for my s3/s5stevec1975 wrote: ↑Wed Mar 06, 2019 12:09 pm
also other alternatives to stock axles are MAXLE. I believe i saved 60g on the pair.
- stevec1975
@Gary71: The bike came with upgraded wheels out of the box (Hunt 50 Carbon Aero Disc @ approx 1500g) so I don't have a full stock weight, however based on the stock wheel (DT Swiss P1800 Spline 32 Disc @ 1821g), it would have come in at approx 8.45Kg..
Current bike weight is 8.13Kg.. without pedals, Based on this, I think getting it to around 7.8Kg is just about possible.
- stevec1975
No, I don't think I will either (I would have to remove the Disc hoses and internal cabling, which would be a pain in the ass)
