My TIME Alpe d' Huez
biwa
by biwa
Anyone with a size M Alpe d'Huez know/could measure the c-t length of the seat tube? The geometry doesn't show.
Perp
by Perp
biwa wrote:Anyone with a size M Alpe d'Huez know/could measure the c-t length of the seat tube? The geometry doesn't show.
Just got my M frame. What exactly is c-t? BB to TT or post?
Sent from my Pixel 5 using Tapatalk
Perp
by Perp
Just noticed the seat tube doens't go higher than teh TT. It's 52cm from center of BB to top of top tube
biwa
by biwa
Perp wrote:
Fri Jul 09, 2021 12:19 pm
Thanks for your help. I mean from the centre of BB to the end of the seat tube where the seatpost inserts (highlighted in the red box in the pic). Is that how you measure it at 52cm?
Perp
by Perp
Yes, that's what I measured
JimmyM13
by JimmyM13
Just checking with the group but anyone else had one of those ti bolts snap? I bust one today (bikes a year old) but obviously not a quick fix and going to be a warranty claim:-(
Kumppa
by Kumppa
Which bolt do you mean?
jmagoulas
by jmagoulas
If I had to guess one of these?
Kumppa
by Kumppa
^ is so, no problem after 2 years. Always using torque wrench as those look a little bit fragile for over torque.
unclearv
by unclearv
Looking at the geo charts but I see a dip in the top tube where the stem is mounted.
Can anyone confirm that the stack height in the chart starts at the top of the headset cap or if it is a across the top of the top tube so +5 or +3mm?
fersl7
by fersl7
Time Alpe d huez 01, I have a problem with the titanium bolt (screw)that goes in the frame that holds the seat clamp, it was released from the frame and is loose, it is glued or has a metal insert, how is it fixed to the frame??
jmagoulas
by jmagoulas
fersl7 wrote:
Thu Jul 28, 2022 2:24 pm
I believe bonded in during the layup process. Over torqued?
fersl7
by fersl7
Well no over torqued because in the frame instructions say it's 6nm and I have a 5nm tool , so I guess is a factory defect
I don't want glue in my frame
wheelsONfire
by wheelsONfire
fersl7 wrote:
Sat Jul 30, 2022 4:03 am
Glue will not hold either, not the typical super glue anyway!
Interested to read if you get a Time repair on this or a DIY from you or a bike shop.
Bikes:
Open *UP* (2016.04.14)
hogehoge
by hogehoge
Does anyone know what the maximum extension of this Time seatpost is?
I'm between sizes and am concerned the seastpost might be quite short.
Thanks
