2019 Scott Foil Premium
- fanatic278
I've been using this site to steer my new bike choice but never contributed before, so only fair that I introduce my new bike! I built it all up from components. I made a few savings here and there, but can't pretend it was cheap (except to my wife).
2019 Scott Foil Premium Team Edition Frameset (XXL/61cm) - frame 1140g and forks 322g uncut
Ultegra R8070 Di2 groupset
Hunt 50 wheelset
Schwable Pro One tubless tyres (25mm)
Pro Stealth Saddle
Specialized Hover bars (44cm)
Syncros Aero Foil stem (100mm)
KMC X11-EL chain
Bontrager RXL bottle cages
Weight = 7.7kg according to my cheap luggage scales. Which I think is pretty impressive for such a big aero bike.
Hunt 50 wheelset
Pro Stealth Saddle
KMC X11-EL chain
Using Tapatalk
One of my favourite bikes was a 2012 Foil...really like them & would consider buying one again
I’m guessing It’ll be difficult to loose weight from the usual places, seat post, stem as they are aero & designed specifically for the bike
Where’s the dry stone wall, somewhere in the Uk?
Building Spec Allez
Sold
Fuji SL 5.5kg viewtopic.php?f=10&t=157704
Sold -
Izalco Max Disc 6.7kg http://weightweenies.starbike.com/forum ... o+Max+disc
Sold
Sold -
- fanatic278
Bars and seat could be lighter, but I like them. I'm happy with the weight though. It's only 100g heavier than the old rim braked Cervelo R3 that it replaced.I’m guessing It’ll be difficult to loose weight from the usual places, seat post, stem as they are aero & designed specifically for the bike
The wall is in Aberdeenshire, Scotland.
Using Tapatalk
That's very light for an uncut disc fork with paint still on! And it's aero with probably generous clearance. Did you weight it after the cut or plan to? Can you photo and measure fork clearance?
- fanatic278
I didn’t weight it after the cut, but it won’t be too different as I only took about an inch off. I won’t be doing any more weighing now that the hoses are threaded into the frame. Big fork clearances as shown below:That's very light for an uncut disc fork with paint still on! And it's aero with probably generous clearance. Did you weight it after the cut or plan to? Can you photo and measure fork clearance?
Using Tapatalk
I got the same frame as discount deal from my local shop. It looks nice, but seems I`m not that lucky on weights. Frame is M (54) and weight is 1130g for the frame without hanger and other stuff, and the fork is 408g uncut. Seatpost 201g
It`s labeled as a "1 ST SAMPLE" on the box, so that might be a reason for higher weights, but not sure.
