Something Special(issima)
Imaking20
by Imaking20
Coffee shop build :)
Current:
Acid Minty
Retired:
Wilier Wonka | The Dentist | The Bucket List | Specialissima | Evo | T2 | Blue | Project C6.0 | Felt AR FRD | Colnago C59 | S-Works Tarmac SL4| S-Works Venge | Wilier Cento1 SL | Tarmac SL2
kgibbo1868
by kgibbo1868
Looking forward to this! :-)
Pain is my friend!
PokojniToza
by PokojniToza
Great. I have the same frame, though I hope you will build your's more to WW standards:)
PokojniToza
by PokojniToza
BTW, I have a question - Did you choose a celeste seatpost clamp or they sent it like that?
Imaking20
by Imaking20
It came with the celeste Carbon-Ti clamp
Also celeste carbon-ti bottle cage bolts - which are a nice touch - but won't be used as they're incompatible with Carbonwerks cages
My build sheet puts the total build at low 5.4kg... but I'm starting off in a deficit... because Italians
Granted, the frame weight includes derailleur hangers and cable guides. All of which appear fairly... robust. And lower bearing race installed on the fork already.
Current:
Acid Minty
Retired:
Imaking20
by Imaking20
Also ships with an FSA SL headset - so I'm glad to not have to buy lighter bearings in the pursuit of #gramz
And a new crank showed up today as well. It was like Christmas... except for the incorrect seatpost that showed up :(
The gloss seems thicker than the last M3 I had
Current:
Acid Minty
Retired:
spdntrxi
by spdntrxi
I love that bike.... if it was DM brakes I probably would have got one.
Imaking20
by Imaking20
I'm definitely sold on the DM brakes on the Wilier. It will be interesting to compare against standard mount EE that will be on this bike.
Current:
Acid Minty
Retired:
KarlC
by KarlC
Crazy nice Coffee shop build !
Johnny Rad
by Johnny Rad
Frame size?
Digging the THM crank. I’d like to do the same one day.
What group are you pairing it with? Read somewhere the chainline with THM is different than SRAM, but wonder if it matters...
LouisN
by LouisN
This should be great :beerchug: !!
Louis :)
Imaking20
by Imaking20
53cm frame so may end up needing a 130mm stem. Will be built with SR11 which should arrive Friday.
Current:
Acid Minty
Retired:
spdntrxi
by spdntrxi
Imaking20 wrote:
Thu Jan 10, 2019 2:52 am
When I had my Parlee Z-Zero rim brake bike... I actually used a fork from a Colnago V1R so I could use DM brakes on the front atleast...
mrlobber
by mrlobber
Boy that fork is heavy though :?
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
reedplayer
by reedplayer
claimed frame weight is 780gr. for size 55, +/-5%. black version. :shock:
but i think its simply a typing error, they accidentally added the "-". its supposed to say "780 gr + 5% for size 55" ...
seriously: why "+/-5%" for a matte frame? there are so many manufacturers (cdale, scott, focus,.... among other idiots, advertising correct weight-specs) who produce frames with relieable weight differences of maximum +/-5 gram, in equal sizes and matte paint.
dont want to provoke a debate. but, sorry, i had to get rid of this, because i am bit annoyed from the habit of some manufacturers, obviously trying to get potential customers by stating weights that they know to be false.
