Something Seven 622 SLX Carbon / Ti Luged
Discodan
by Discodan
I get it, it’s definitely neater and the weave is a better match so it’s not meritless to add the sleeve. The original wasn’t bad by any stretch of the imagination, it’s just better now. Of course you haven’t told us the weight penalty for the sleeve.
How did you get the flare in the top of the sleeve that goes over the clamp, it looks like it’s custom for the job
themidge
by themidge
It doesn't look as good either, the seat cluster and clamp look out of proportion (too small) with the 31.6mm 'post'.
KarlC
by KarlC
jbaillie wrote:
Tue Jan 22, 2019 3:44 am
duuuuude...
Even on a forum where everything is vain, that may take the cake. The 31.6 post is just sitting atop the clamp? You're going to get a TON of vibration coming through to the saddle.
The 27.2 you had installed looks absolutely fine.
LOL yes I know a 27.2 is fine, but its fun to change things up. Currently the 31.6 post is just setting there as I wanted to see how it looked, next I will bond the 2 parts together to become one so it will not just be sitting on top of the clamp .
Discodan wrote:
Tue Jan 22, 2019 4:12 am
This change added 20 grams, so not bad. The flare at the top is how the seat post came, its just a cheep post to try this experimint with.
themidge wrote:
Tue Jan 22, 2019 12:57 pm
Its still looks off to me also, this is just a cheep post to try this experimint with, if it works I can do it with any 31.6 seat post.
Also in the photo it looks like seat post is a bit wider but size wise its 31.6 and the seat tube is 32.
I think the reason the seat post looks wider is that its painted black and the rest of the carbon tubes are nude.
If I end up liking this I may sand the paint off the UD carbon seat post so its a better match, or buy another 31.6 post.
The best match would be to get a matching carbon tube scrap from Seven and make a seat post out of it.
KarlC
by KarlC
3T Ergonova LTD Bars that could use a bit more sanding and I left the grit there for the shifters, not sure its really needed tho
oldturd
by oldturd
wow very nice, dropped almost 10grams
KarlC
by KarlC
oldturd wrote:
Wed Jan 23, 2019 1:13 am
All of the gray painted areas where very thick, I kinda want to keep sanding to see if I can get them under 150 grams but its a pain.
eric01
by eric01
Lol! The 31.6 seat post is absurd! Trek seat cap I suppose. Very anti weight weenie.
How do you plan on bonding it? Is it safe?
KarlC
by KarlC
eric01 wrote:
Fri Jan 25, 2019 12:04 pm
No issues so far
I think I could use some different wheels soon
KarlC
by KarlC
glepore
by glepore
Yesss. I've had ccu's and various lightweights, but never Boras. Had a deal on the classifieds here but the guy flaked. They look AWESOME on that frame. If I hadn't just built an Ottrott that fits like it was spec'd for me I'd build that ebay frame like pic above. Chapeau
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
KarlC
by KarlC
KarlC
by KarlC
New shoes, FSE 25T, hoping they come in right at 1000g.
KarlC
by KarlC
RyanH wrote:
Tue Jan 15, 2019 12:54 am
Just swap the brake pad holders with kcnc ones. Campy dual/single brakes with those pad holders weigh around 233g and the Campy brakes have arguably the best brake feel, even over 9100. Planet X brakes are fine but not quite in the same league as the rest of the spec on your build.
So I did end up swaping out the pad holders on my Campy Record brakes and lost some grams and I was going to leave it at that.
Then these brand new in the box EE's came up for sale localy for a deal so they are likly up next. In the back of my mind I want to get this bike under 13 lbs / 5.9 kg so they will help with that. Time to sell the Planet X brakes
KarlC
by KarlC
Campy Record brakes with lighter weight pad holders removed and EE Brakes installed for a loss of 106g
RyanH
by RyanH
Those are both dual pivot I think. The single pivot rear saves something like 30g.
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
