Something Seven 622 SLX Carbon / Ti Luged
KarlC
by KarlC
KarlC
by KarlC
Some crap photos from a great ride today
Klaster_1
by Klaster_1
KarlC wrote:
Sun Jan 13, 2019 4:25 am
Tonights project
Any second thoughts about sanding off grip areas? After some considration, I decided against that on my Ergonovas and only went for regular paint. My new Darimo handlebar doesn't have those though, so it might not really matter with a scoop of CF grip paste.
KarlC
by KarlC
Klaster_1 wrote:
Sun Jan 13, 2019 6:58 am
Tonights project
I dont think it will make much differance either way
nobuseri
by nobuseri
Looks great; nice work.
Cicli Barco XCr Road
Moots VaMoots
Parlee Z1
SuperX Hi-Mod Disc
KarlC
by KarlC
dgasmd wrote:
Fri Jan 11, 2019 2:04 pm
Just curious as to why the Chitmano DA cassette instead of the Campy one. Also, could swap the brakes for eebrakes and drop
Some weight there. Lighter inners and putter cables would help too
I have these brakes here but not sure if they are worth using..... Planet X CNC ..... would drop 100+ grams if I do
RyanH
by RyanH
Just swap the brake pad holders with kcnc ones. Campy dual/single brakes with those pad holders weigh around 233g and the Campy brakes have arguably the best brake feel, even over 9100. Planet X brakes are fine but not quite in the same league as the rest of the spec on your build.
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
glepore
by glepore
RyanH wrote:
Tue Jan 15, 2019 12:54 am
Spot on. There's weight, and then there's bikes like this where its about the feel and experience. I've used those brakes and they work, but they're not a luxury performance item like DA, Campy SR, THM etc. I'm currently building an Ottrott (similar ti carbon mix but older and therefore heavier) with ee's simply because I had them-if I hadn't I would have likely gone with SR.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
KarlC
by KarlC
Whats the weight of the kcnc brake pad holders with bolts and washers?
The brake pad holders off these Planet X are 27 grams with bolts and washers.
KarlC
by KarlC
NM I found this ...... Thx Ryan
RyanH wrote:
Sat Oct 15, 2016 4:45 am
Thanks all for the kind comments.
Got some KCNC pad holders for $50 with pads that should fetch $20 or so.
KCNC Pad Holders with Hardware @26g:
Super Record Pad Holders with Hardware @ 46g:
Imaking20
by Imaking20
I'd just use the Planet X holders. That's how I've got my wife's Campy brakes setup. I think the PX holders are within like a gram or two of my EE holders.
Current:
Acid Minty
Boone
Retired:
Wilier Wonka|The Dentist|The Bucket List|Specialissima|Evo|T2|Blue|Project C6.0 | elt AR FRD|Colnago C59|S-Works Tarmac SL4|S-Works Venge| Wilier Cento1 SL|Tarmac SL2
KarlC
by KarlC
Imaking20 wrote:
Tue Jan 15, 2019 2:22 am
Yes will do thx !
KarlC
by KarlC
In weightweeine mode 6.1kg / 13.44lbs, still a long way to go to get under 5.9kg / 13lb .......
KarlC
by KarlC
Some of you may not understand but one thing I dont like about this frame is the 31.6 seat tube with the 27.2 seat post, it just looks off to me. It would look much better if they cotinued the flow of the 31.6 seat tube with a 31.6 seat post.
So thats what I did, I added a 31.6 seat post by sliding it over the top of a peice of a 27.2 seat post tube.
It looks better in my mind but I still need to ride it and see how it feels.
1st photo with the 27.2 seat post
Next set of photos with the 31.6 seat post
jbaillie
by jbaillie
duuuuude...
Even on a forum where everything is vain, that may take the cake. The 31.6 post is just sitting atop the clamp? You're going to get a TON of vibration coming through to the saddle.
The 27.2 you had installed looks absolutely fine.
