My R5Ca
COSTA
by COSTA
I’ve changed a few bits over Christmas & managed to drop the weight. Although I’ve gained from the festivities :noidea:
I’ve changed a few bits. Brakes are on the list in the coming weeks
Klaster_1
by Klaster_1
Housing and cables are missing from the list.
COSTA
by COSTA
Klaster_1 wrote:
Sat Jan 12, 2019 5:16 am
They’re just the shimano ptfe dura ace ones. I’ve not weighed them as it was a bit awkward. I didn’t want to roll them up too tight to fit on the scales or take it apart once set up. I might be able to do it from the ones I’ve removed to get a rough ball park figure.
Klaster_1
by Klaster_1
COSTA wrote:
Sat Jan 12, 2019 8:29 am
I'd ballpark 40g for shifting housing/ferrules and 25g for both shifting cables. No idea about brake stuff, but it's probably heavier, I'd say another 50g.
mike
Resident Pro
by mike
Do not drill this frame for internal routing. It is fine the way it is. If you want electronic just e tap is good enough. But if you want lightest go for mechanical red
b5000
by b5000
mike wrote:
Sun Jan 13, 2019 2:52 pm
Seedster
by Seedster
Yeah I would just go eTap and skip drilling this and voiding the warranty. I actually saw the exact frame built up locally and the weight with eTap, THM and lightweights was under 14lbs. impressive.
mnmasotto
by mnmasotto
Did you use loc-tite when you pressed the bottom bracket bearing into the frame. Does your bottom bracket make any noise? I am currently building a R5ca and trying to choose which configuration will not creak!
COSTA
by COSTA
mnmasotto wrote:
Tue Jan 29, 2019 6:41 am
I used the parktool stuff primer & retaining compound. its worked fine so far eith enduro ceramic bearings.
Dont worry people ive not drilled any holes. I went for the dura ace 9100 groupset in the end but with a sram red cassette. its shifts pretty well & is a good saving over the dura ace item. I might change my saddle for a berk next, but im finding it hard to take the jump. Pretty costly if i dont get on with it.
COSTA
by COSTA
Took it out for a spin yesterday, love it!!!
gurk700
by gurk700
Ooops nvm didn't see the next page :oops:
Enjoy the ride!
gurk700
by gurk700
I used Hambini BB and retaining compound in 2 different Cervelo's. I don't remember what creak sounds like.
frommel
by frommel
COSTA wrote:Took it out for a spin yesterday, love it!!!
Beautiful
