The Fling: A #metoo Izalco Max
themidge
by themidge
rlpaul wrote:
Wed Dec 26, 2018 3:18 pm
Air does end up adding a few grams.
A surprising amount of air, it turns out. I just weighed my Vitus' front wheel with no pressure, 1042.5g, with 120psi it weighs 1047.5g (22mm tubular). Five grams for one wheel!
Still, 32 unaccounted for grams seems like a lot of air and grease :noidea:
glepore
by glepore
Ryan, c'mon, a stem that's almost 200g?
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
Imaking20
by Imaking20
I suspect if he knew where all the "misc" weight was there wouldn't be a separate row for "misc"...
Jugi
by Jugi
glepore wrote:Ryan, c'mon, a stem that's almost 200g?
It's so damn sexy on the bike, but sticks out like a sore thumb on the spreadsheet. Image
RyanH
by RyanH
I know, I know, it's the antithesis of WeightWeenies but it is noticeably different in how the bike handles. I thought it was going to be temporary but I think this is a 50g penalty worth paying. I may order up a Pro 7s to see if that's a reasonable compromise but I dunno if I'm going to be bothered to replace the stem as I think it looks pretty cool (except maybe for the stealth version). I mean, the bike is at 5.7kg right now, which is under my maximum weight spec of what I consider light enough.
I still have a few loose ends to tie up on the build. I'll replace the bolts with Ti. I have a Tune seatpost clamp that should save 10g. Ti seatpost bolts (4 pack) should be arriving some day soon and I need to cut a good chunk off the Ritchey post.
glepore
by glepore
Jugi wrote:
Wed Dec 26, 2018 9:45 pm
Post of the year, on 12/26 even.
northwestern
by northwestern
I almost bought an Izalco Max myself. Team AG2R blue frame, etap, Zipp 303, quarq for just $2800.
Also, the look of the stem is worth the extra 80 or so grams.
rlpaul
by rlpaul
I'm not one of those people that can tell the difference in stems, but I can in other parts, so I understand the sentiment. It's one of the reasons why I never considered a sub-300 gram fork until more recently.
I think the Zipp aesthetic is hit or miss, but it does match the frame nicely.
RyanH
by RyanH
Today was a good day, saved 43g without spending anything (kinda).
Cut the seatpost to have 100mm inserted length and swapped in a ti bolt for a savings of 25g, Ritchey is now 137g:
Ordered a Tune seatpost clamp while ago, savings of 8g:
Swapped ti bolts in on the brick of a stem:
Put lightweights back on since I finally got around to gluing up the rear:
Current weight is 5.48kg.
asiantrick
by asiantrick
RyanH wrote:
Mon Jan 07, 2019 4:29 am
Hey Ryan,
What size is the Tune clamp? 31.8? Any issuse with seatpost slipping while using the clamp so far?
I'm trying to lose some weight on the Focus also, but worry about slippage.
Thanks,
RyanH
by RyanH
I just put it on and rode it once, but it was snug when I put it on. It's 31.8. I've used their clamps on all of my builds and they've all been super reliable, even with repeated removing and putting back on. Never have seatpost slipping issues with them on other builds.
KCookie
by KCookie
Hey Ryan,
Can you tell me what pads your using please, I can see they aren't the specific Lightweight pads. Will these be staying on, if so do you find them better. I'm still experiencing pulsing under braking and feel I need to change from their pads.
Cheers
RyanH
by RyanH
Hey Kevin, they're the Campy red pads. I didn't notice them being better braking per se but they eliminated my noise issue.
KCookie
by KCookie
Ok, many thanks for the reply Ryan. Think I will have to stay with the Lightweight pads then. ☹️
VTR1000SP2
by VTR1000SP2
KCookie wrote:Ok, many thanks for the reply Ryan. Think I will have to stay with the Lightweight pads then. Image
No personal LW experience but have you tried cork pads?
Focus Izalco Max - 4.84kg without pedals
Cervélo Áspero - 8.28kg
Trek Madone SLR Rim - 7.73kg
Standert Triebwerk Disc - 8.47kg
