VTR1000SP2
by VTR1000SP2 on Mon Dec 03, 2018 4:15 pm
Calnago wrote:I agree, I like the lines on this frame. I don’t see any port on the drive side downtube in the event you wanted to run a mechanical drivetrain. Is this an electric only frame?
Correct. They came mechanical or electronic, not both.
Focus Izalco Max - 4.84kg without pedals
Cervélo Áspero - 8.28kg
Trek Madone SLR Rim - 7.73kg
Standert Triebwerk Disc - 8.47kg
RyanH
- Moderator
VTR1000SP2
by VTR1000SP2 on Sat Dec 22, 2018 9:55 pm
Looks good on there
RyanH
- Moderator
by RyanH on Sun Dec 23, 2018 2:41 am
Wilier is gone, sadly. Awesome bike, but horrible experience with disc.
I should provide an update on the carbon-ti rings. I had trouble setting them up on the litespeed, after about half an hour of dicking with it, I just assumed they weren't going to shift as well as I had been used to with the BOR rings. In a bit of a whim, I put them on again when I got the Focus. They seem to be shifting much better. In certain combos there will sometimes be a slightly clunky small to big up shift but overall it shifts better than most SRAM setups.
VTR1000SP2
by VTR1000SP2 on Sun Dec 23, 2018 5:30 pm
The noise... ugh
RyanH
- Moderator
by RyanH on Sun Dec 23, 2018 11:54 pm
VTR1000SP2 wrote:The noise... ugh
It's okay, this thread is a safe space. You don't have to hear the tisk tisk tisk, pings, pops or screeching banshee wailing here.
RyanH
- Moderator
rlpaul
by rlpaul on Wed Dec 26, 2018 3:18 pm
Everything threaded and pressed in will be greased, threadlocked, or ti-prep/anti-seized, that adds up. Air does end up adding a few grams. Also carbon paste.
A scale that isn't perfectly calibrated might add a few grams overall as well - my scale actually reads slightly heavy, so my build sheet ends up 20 or so grams heavier than the actual build.
