Doing another V2R only this one is a 2019 Disc version otherwise its the same size and a Gloss Black Art Deco Paintjob. I plan on moving some parts over to the disc from the rimbrake to try and keep it reasonably light. I have a set of Tubular Bora 35s on the way and a Record 12sp mech groupset coming as well at some point. I will be moving the THM stem, Darimo seatpost,SMP Composit carbon rail saddle and heavily modified seatclamp over to the disc.
The threaded piece on the rear stay was somewhat misaligned and the axle was tight going in right from the first thread so I shimmed the rearstay piece which was a definite improvement.
Colnago V2R TNBK 54s
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2019 Colnago V2R Disc Brake
So my Record groupo and Bora One 35 wheelset came in at the same time and still need to order couple 160mm rotors along with some Magura Mineral Brake fluid just to have it in case I get sloppy with the hose setup. The selection of Campy Rotors is pretty much non existant for the moment so the rotors are Magura but I think I have everything to do a complete build. The rear TA was tight going into the threaded nut that is coupled up with the RD hanger so I had to shim up one side of the nut side to align it to the axle but now the axle threads in easily. Hopefully this wont be the cause of creaking noises. I also didnt get the mounting bolts for the calipers but at least the wheelset came with locknuts for the rotors. I have weighed all the parts but just need to load the pics. I will weigh the wheels when the rotors come in.
Frame: Colnago V2R Disc 54s 1.09kg
Fork: Colnago .455kg
hanger: Colnago
Headset: Colnago
seatpost clamp: Colnago 0.028kg
Seatpost: Darimo 350mm 3K Carbon 0.094kg
Seat: SMP Composit Carbon Rails, Black Leather covering removed 0.139kg
Stem: THM Tibia 120mm 6 Degree .088kg
Bar: 3T Super Ergo Team CF Handlebar 44mm 0.204kg
Bartape: Fizik Tempo Green
bottle cages and hardware: Supafly 0.11kg
Outer Cables: Campy
Inner Cables: Campy
Brakes: Campy Caliper W/pads front 0.132kg Rear 0.131kg
Rotors: DA 160 0.116 ea. NOW8 0.089 ea.
Front Mech derailleur: Campy Rec 0.082kg
Rear Mech derailleur: Campy Sup Rec 0.200kg
Crankset: SR P2M eco 0.638kg 175mm CR Rings 36/52-0.157 W/fasteners
Bottom Bracket: CR W/BB86 cups
Chain: CR with KMC quick link
Cassette: Recon 29/12 12sp 0.202kg, Edco Shim. 29/11, 12sp-0.195kg
Wheels: Campy Bora One 35 Tubular 1.08kg-Front W/Rotor on and Vittoria Control, 1.38kg-Rear W/29-12,12sp cassette/Rotor on Vit Cntrl.
Shimano C60 Tub Rear: 0.82kg no cassette,no Rotor, Front: 0.66kg, no Rotor. But DA Rotors are presently mounted @0.116kg/ea.
Tires: Vittoria Elite, Corsa Graphene, Rubino 25mm
Pedals: Pave Speedplay Zero W/Ti spindles, Endcap Bolts,install Ti Bowties 0.182kg
Polar/garmin/computer mounts: Garmin Edge 530/ Radar RTL 510
Tape/glue: Vittoria glue
Radar Mount: Modified Garmin Mount 0.013kg
Complete Build: 7.06 kg W/Campy Bora One Wheelset-Recon Cassette and NOW8 Rotors mounted.
hanger: Colnago
Headset: Colnago
Outer Cables: Campy
Inner Cables: Campy
A few pics with bike on scale and in the wild as a complete build.
New AXS Red group added.
