"BLACK BETTY" 2019 S-works Tarmac project
ahhhhh......SO good
I can taste the excitement from every single one of Nick's posts. lmao
Hahaha!!! You can probably imagine the drool dropping from my lip too thenasiantrick wrote: ↑Thu Nov 08, 2018 6:19 pmI can taste the excitement from every single one of Nick's posts. lmao
A 20g penalty for a non-WW expander is quite a lot tbh but it looks like you're saving loads and loads of grams everywhere else anyway. If you don't trust the Ultrastar then I'd go with with the MFCK one or whatever same open catalogue design like it (JRC).
Took my etap shifters off the bars
Aligator ilink Brake housing and liner
Bar end plugs (Cheap plastic no name)
Approximate brake cable length (This is front and rear)
Lizardskin 1.8 race tape
Here she is! 777g for frame (Size 54). Fork seems a little heavy coming in at 345g, but i'll be cutting that. I thought the fork was supposed to be claimed sub 300g?
- VTR1000SP2
Maybe you got the wheelie friendly Sagan edition fork in black
42.
I just say am sworks fork that had some steeper cut off and left a 25mm conical spacer under then stem. The piece cut off was 42g so I should get a good 50g cut off the front fork since I'll be slammed. That seems like a lot but based on what I saw and weighed today at bike shop, I would imagine 50g is pretty realistic
If only I could get my rear end comfy on the Sworks power saddle I'd be able to save another 75-80g on the build! Had to use the power expert with level 2 padding. Might try to pick up a good conditioned used sworks juat to try it out again. The expert has been the answer for my bum though.
My goal was to get down into thw sub 13lbs range (under 5.89kg), but with my 4.5 clinches, expert saddle and aero bars I dont think it will happen.
Seatpost - Zero degree offset Sworks post (Uncut) - 400mm so I would imagine I would cut off at least 50mm.
And already swapping things out for lighter and gooder! lol
no name top cap and bolt
ETA on build completion?
Waiting for my bars, stem and Fetha garmin mount to come in. Bars wont be here till end of next week as they were on back ordered. Stem should be here early next week, not sure on garmin mount as it is coming from Australia. I'm traveling for work all next week so that will keep me distracted. I'm HOPING not this coming weekend but the following weekend. fingers crossed
- Similar Topics
- Replies
- Views
- Last post
- 16 Replies
- 5042 Views
Last post by Ronin416
Wed Dec 19, 2018 5:06 am
2019 S-Works Tarmac SL6 Disc (6,900g)
by Rich_W » Tue Oct 30, 2018 8:21 pm » in Introduce Yourself / Gallery - Please use metric weights. - 79 Replies
- 9290 Views
Last post by Rich_W
Tue Jan 22, 2019 6:36 pm
2019 S-Works Tarmac SL6 Disc QuickStep
by Cdavies102 » Tue Jan 29, 2019 7:45 pm » in Introduce Yourself / Gallery - Please use metric weights. - 13 Replies
- 1274 Views
Last post by matvalse
Sat Feb 16, 2019 9:05 pm
- 22 Replies
- 2103 Views
Last post by benjieb
Mon Jan 21, 2019 10:25 am
2019 Project>CERVELO R5 disc Ltd
by Naturel » Mon Feb 11, 2019 8:10 pm » in Introduce Yourself / Gallery - Please use metric weights. - 11 Replies
- 1176 Views
Last post by rexyi1990
Sun Feb 17, 2019 2:46 am
