"BLACK BETTY" 2019 S-works Tarmac Update Now 6.07kg
I had one on a tri-bike and my last road bike for shits and giggles. I found the shifting really smooth..better then OEM? not really.. but not worse either. What it did allow on my road bike was to use the 32t cassette which I could not on OEM short cage (this was SRAM eTap ) I did not pay retail..no way I'm buying one for $4-5hundo. I probably would NOT put one on the road bike again.. Tri-Bike yeah maybe ?
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
Good to know, thank you for the feedback.spdntrxi wrote: ↑Mon Nov 12, 2018 5:45 amI had one on a tri-bike and my last road bike for shits and giggles. I found the shifting really smooth..better then OEM? not really.. but not worse either. What it did allow on my road bike was to use the 32t cassette which I could not on OEM short cage (this was SRAM eTap ) I did not pay retail..no way I'm buying one for $4-5hundo. I probably would NOT put one on the road bike again.. Tri-Bike yeah maybe ?
Good thread! Want to see more bits! What wheels are you going to use?
Just waiting for some final parts to come in. I'll be using my Enve 4.5 clinchers on it.craciunptr wrote: ↑Tue Nov 13, 2018 1:03 amGood thread! Want to see more bits! What wheels are you going to use?
- numbers505
- Contact:
Where did you get your Specialized Sworks Carbon Power Meter?
Was able to get through bike shop and customer. Guy bought new tarmac and came with it, though he uses SRM so I bought it off of him through the shop. Was lucky to be in the right place at the right time. Lucky menumbers505 wrote: ↑Tue Nov 13, 2018 6:10 amWhere did you get your Specialized Sworks Carbon Power Meter?
That! I'd love to try it/have it but not at the price range they are selling...spdntrxi wrote: ↑Mon Nov 12, 2018 5:45 amI had one on a tri-bike and my last road bike for shits and giggles. I found the shifting really smooth..better then OEM? not really.. but not worse either. What it did allow on my road bike was to use the 32t cassette which I could not on OEM short cage (this was SRAM eTap ) I did not pay retail..no way I'm buying one for $4-5hundo. I probably would NOT put one on the road bike again.. Tri-Bike yeah maybe ?
Road // 2023 S-Works Tarmac SL8 | Shimano Dura-Ace Di2 | Roval Rapide CLX
Gravel // 2023 Specialized Crux Pro | SRAM Force AXS | Roval Terra CL
Retired // 2022 S-Works Shiv TT // 2021 S-Works Tarmac SL7 // 2019 Specialized Allez Sprint Red Hook
Extralite Hyper stealth stem 100mm -12mm
Sworks Aerofly II bars 42
Well good news and bad news. Bike is built up and it looks absolutely stellar! Having issues with the shifting on the chainrings but will bring back into have then try to dial in and fine tune. If not, ill simply go with praxis, no problem. Other thing is that it is SO much heavier than i imagined it would be!!!! 14.4lbs with pedals, cages and garmin. Not happy about that AT ALL considering the parts i have on it. But i knew the enve 4.5 clincher and saddke would be a weight penalty.
Im looking into swapoing out the power expert for the sworks power mimic which is no different in shape, has carbon rails and shell with the level 2 padding i want which results in a 70g savings.
Will get a picture up in the morning.
Here are some REALLY quick shots. wife was trying to get some things ready for Thanksgiving so I snuck out out lol
steering tube will be cut, I'm just playing it safe to make sure this set up works. Once I get out on a couple rides, it will be cut appropriately. Still need to make adjustments to saddle tilt, but the seat height is dead on and feels great.
This is what it should look like with that steerer cut..
