Trek madone slr9 disc - 8,2kg - project one
SchallUndRauch
by SchallUndRauch
So apparently when you buy a Campgnolo Super Record 12x with disc brakes, you do not pay enough for a set of screws to fix the rear flatmount caliper.
Since my Madone SLR frame is still being produced, and I'd love to have everything together bevore it arrives, my question is: Could a Madone owner be so kind and do me the great favour of measuring the thickness of the left chainstay where the screws go through, as in the attached pic? I'd really appreciate it!
Fisherfreerider
by Fisherfreerider
It is 25mm on all Trek flat mount models.
SchallUndRauch
by SchallUndRauch
Thanks!
rexyi1990
by rexyi1990
looks pretty cool
cajer
by cajer
What's the mininum spacer height required for use with the aero stem/bar stem? As the 50cm bike is a bit tall for me.
DavideChristiani
by DavideChristiani
I try to figure out how to get my Madone SLR6, which I build up with an R9070 Dura-ace Di2 group below 8,4kg.
Replaced the heavy Bontrager wheels with lighter AIE wheels, with extremely light rotors (71gr/piece)
Without wheels it still weighs 5,44kg.
Wheels weigh 2,93kg included cassette and tubeless GP5000 tyres.
I see similar bikes here under 8,2kg, but can't seem tot shave off extra weight without spending an excessive amount of €€...
bruno2000
by bruno2000
DavideChristiani wrote:
Thu May 09, 2019 2:33 pm
What pedals are you using? Maybe try something like Speedlplay with TI axle or Look Keo Blade carbon with ti axle?
ryanw
by ryanw
Goes to show that Cervelo and Spesh have got the lightest aero bikes.
My S5D is just under 7.5kg fully built and ready to ride in a 56 (110mm stem) with power meter. The Venge Pro I demoed was 7.3kg with pedals but no PM, mountm cages and short stem.
Allez Sprint Disc - 7.60kg
SL7 S-Works - 6.72kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
DavideChristiani
by DavideChristiani
bruno2000 wrote:
Thu May 09, 2019 2:44 pm
I have Look Keo Max 2 pedals now, but will be installing - and yes, I suppose these will add weight - Vector 3 pedals in a few weeks.
Look Keo Max 2 pedals are not the heaviest of pedals, so I don't think replacing them will reduce a lot of weight. :roll: :wink:
Noctiluxx
by Noctiluxx
ryanw wrote:
Thu May 09, 2019 2:56 pm
Not sure what those wheels are, but my 2019 Madone SLR (rim brake) comes in at 7.2kg’s with DA 9150, Bontrager XXX 6 wheels, XXX saddle, Speedplay Zero titanium, and Tune bottle cages. The disk version is 300 grams more making it 7.5kg’s.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
ryanw
by ryanw
Nope, out the box a 56 SLR9 Disc is 7.76kg with 140g Speedplay Ti pedals and no cages.
IG: RhinosWorkshop
DavideChristiani
by DavideChristiani
ryanw wrote:
Thu May 09, 2019 3:39 pm
That's an enormous difference.
Even mine is originally a 56 SLR6, I replaced the group with Dura Ace, so the weight difference with an SLR9 shouldn't be so great.
The wheels I use, handbuilt, have been built up to be 300gr lighter than the Bonts Comp 5 the SLR6 comes with.
All that, plus rotors that weigh half of the Dura Ace rotors, brought the weight down with approx. 500 gr and I was happy with that.
But now see the same bikes on here, that don't look that much different, weighing 8,2kg and even your SLR9 7.76kg.
650gr can't be all in heavy pedals. :(
jcnz
by jcnz
I have a slr7 56 with duraace stages R, ultegra pedals, long seat mast, gp 5000 28s with tubolito... Weight is 8.21kg.
Hoping to be around 7.8 with xxx4 and duraace cassette etcImage
Sent from my ALP-L29 using Tapatalk
hannawald
by hannawald
You may be surprised how much weight is in details..Speedplay pedals are around 150g, yours may be 100g more.
What kind of tubes you have? You may have 50g or 100g tubes.
What bar tape? Deda Traforato is something like 30g, some tapes are 100g.
May be some lighter axles?
Richards1987
by Richards1987
Does anyone know if you can put a different bar and stem on the 2019 Trek Madone SLR Rim Brake? I am looking at buying the Trek Madone and am trying to bring its weight down as close to 6.8kg as possible and believe the madone specific stem and handlebar is quite heavy (>500 grams). Was thinging the 3T Aeronova team stealth handlebars and 3T ARX LTD stealth stem?
