Trek madone slr9 disc - 8,2kg - project one
joren
by joren
Bad news .
after a few rides I noticed some play at the seat post .
The dealer disassembled everything and put it back correctly , then everything is tightened correctly .
but after the first ride the problem is back .
After that the dealer contacted trek and they need to check up the bike by them self .
Today i was cleaning the bike to send it to trek and then i notticed a big crack under the BB.
Now i need to wait on some more news from trek :(
joren
by joren
Don't worry, I guess they will replace your frame. That's the philosophy of these brands: there is no need for high manufacturing standards. Just make the frame cheap enough and replace it if needed. The customer gets a new frame and the brand seems to provide great customer service. Then everyone is happy.
Fisherfreerider
by Fisherfreerider
That is not a crack.
FIJIGabe
by FIJIGabe
Please provide more photos. From that photo, it appears to be a paint chip, likely from something getting caught between the tire and frame.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
Madone 5, Cobia. I own a lot of Treks.
The tire is far from the frame at this specific area.
izza
by izza
What setting did you have the isospeed on?
jturk
by jturk
[/quote]
Wraping the decals to a white gloss finish , what do you guys think ?
[/quote]
Sick looking bike!
What did you do this with? I've been looking for some options to do the Trek logo in Gold on my Sunburst Madone.
Also, did you end up switching to the 140 discs? I put Dura Ace 140s on mine vs the 160s, I do descend pretty big steep mountain in Utah and haven't had any issues.
Thanks!
Noctiluxx
by Noctiluxx
I love my 2019 SLR but the BB is a POS! I have to pull out the crank and clean it after every few rides otherwise it creaks under load. I have never experienced this on any other bike.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Giant Revolt Advanced 0
FIJIGabe
by FIJIGabe
That’s very odd. I would have the dealer check it out. If it’s out of spec, Trek will fix the issue.
Calnago
by Calnago
Noctiluxx wrote:I love my 2019 SLR but the BB is a POS! I have to pull out the crank and clean it after every few rides otherwise it creaks under load. I have never experienced this on any other bike.
If you have to pull the BB every few rides, something is wrong. If it’s a problem with the frame itself, Trek will replace it. However, I’ve written about this before and I’ll repeat it here. If it’s a Shimano crank, it’s important to get the mechanical preload just right, and it often isn’t. If you were to simply tighten the crank enough for the little pin to fall in place in the spindle and stop as soon as it does, that is likely your problem. You need to tighten the crank till it’s binding, then back it off just a smidge, much the same as you might adjust some cup and cone bearings. Otherwise you might end up just like a brand new Madone that was brought to me, built at the official Trek Store by their mechanics, etc. It had play in it, and aside from being noisy if it had continued to be ridden in that condition the bearings would have worn away at the shell itself due to their constant sliding back and forth as a result of not being installed correctly in the first place.
But either way, that’s unacceptable. Reinstall properly, and if it continues, I’d be contacting your dealer for a replacement. I’m going to assume it’s not something as simple as a dirty chain.
Noctiluxx
by Noctiluxx
Calnago wrote:
Fri Apr 19, 2019 10:48 pm
I actually just remove the crank and rubber seals and clean around it. The pic below is after a week of riding during recent rainfall back in February. No I did not go off road. Even with current sunny weather the BB still gets dirty, though not as bad as the pic below.
Calnago
by Calnago
You call that “dirty”? Ok then.
Well, what I just wrote still applies regarding the preload. I’d pop out those bearings and give everything a good clean and some nice new grease then button it all up properly, ensuring that all play has been removed. Slap a thick layer of marine grease between the bearing and the outer cover, and let it squish to the edges. At least it would provide a better seal to keep out grit and dust from getting between the bearing and shell. That is really what needs to be clean, and make sure all the play is removed from the crank. Did I say that twice.
Lafolie
by Lafolie
Always been an Italian purist , byt the 2019 Project one with the Icon colourway has got my heart beat up !
jcnz
by jcnz
joren wrote:Bad news .
Do you mean lateral play in the seat mast? E.g. Moving from side to side? If so, I have the same issue and its currently in the shop for the 4th time....A common issue it seems.
Sent from my ALP-L29 using Tapatalk
