Chapter2 Rere pearl white
silvalis
by silvalis
Got a warranty on my c2 tere frame and decided to upgrade a few things, including a switch to a Rere. The satin pearl white is fantastic, but looks difficult to keep clean.
Weight went up by half a kg to my tere.
Rebuild was done by lbs so I didn’t weigh anything. Will be doing some replacements and general lightening and filling in the blanks.
Make: Chapter 2
Model: Rere pearl white Ltd medium
Weight: 7.54kg :cry:
Frame: Chapter2 Rere Medium
Fork: Chapter2 Rere
Seatpost: Chapter2 Rere Cut
Frame hardware:
Expander: J&L ultra light---------------------------------- 6.6g
Shifters: Campagnolo Super Record 2015--------------- 353.3g
FD: Campagnolo Super Record 2015 w/ kedge catch-- 82.4g
RD: Campagnolo Super Record 2015 -------------------- 159.4g
Brakes: Campagnolo Direct Mount Calipers 2018
BB: Sram BB86 GXP---------------------------------------- 90g
Crank: Quarq Dzero----------------------------------------- 554.7g
Rings: Praxis Works Buzz Road compact w/kcnc bolts - 142.4g
Bars: FSA KForce compact 42----------------------------- 223.1g
Tape: Supacaz Star Fade Celeste
Bar Ends: Barstow Chainbreaker doodad + supercaz---
Stem: Chapter2 Alloy 110mm -7 w/ Ti hardware------- 127.2g
Saddle: Selle SMP Dynamic------------------------------- 276.6g
Wheels: Fulcrum Speed 40 Dark
Cassette: Campagnolo Chorus 12-27
Skewers: Fulcrum
Tyres: Vittoria Corsa Control G 25
Tube: Vittoria 80mm
Front Total: ------------------------------------------------- 968.0g
Rear Total: -------------------------------------------------- 1440.1g
Cages: Arundel Mandible w/ ti bolts--------------------- 56.3g
Pedals: Shimano Ultegra 6800---------------------------- 258.7g
Garmin Mount: Barfly 2.0---------------------------------- 18.6g
First on the hit list: dig out my ti bolts, expander, tyres and tubes
Chasse patate
moonoi
by moonoi
Very nice, got to see one of those at the launch earlier this year, it looks far better in person than any photograph can do justice to!
What happened to the Tere, if you don't mind me asking.
dacrazy1
by dacrazy1
Mine is 7.2 kg (Size S) Image
Squashednuts
by Squashednuts
moonoi wrote:
Fri Sep 21, 2018 5:21 am
https://www.chapter2bikes.com/tere-range.html
Fuji SL 5.5kg tubs/5.9kg viewtopic.php?f=10&t=157704
Sold -
Focus Izalco Max Disc - Final Weight 6.7kg - http://weightweenies.starbike.com/forum ... o+Max+disc
moonoi
by moonoi
Squashednuts wrote:
Fri Sep 21, 2018 7:47 am
I meant what happened to his Tere that it needed a warranty replacement...
Squashednuts
by Squashednuts
moonoi wrote:
Fri Sep 21, 2018 9:18 am
Caught out trying to be a smart arse
:oops:
Sold -
silvalis
by silvalis
Crack developed at the front of the seatpost wedge slot. It was a first batch/preorder Tere that had the wedge replacements sent out.
I need to check this fit. The shop said as measured, the front (20mm + cap) is marginally lower than my Tere (10mm + cap), but the geo charts and calculators tell me it's higher. Unless the geo charts include the cap on the Rere, but don't on the Tere.
Adding weights to the top post...
Chasse patate
silvalis
by silvalis
I really ought to get a lighter saddle... but I'm just so comfy on this one...
Chasse patate
flying
by flying
silvalis wrote:
Sat Sep 22, 2018 2:17 pm
That is the main saddle criteria IMHO :thumbup:
Many years ago I stopped trying to save weight on saddles or brakes :D
Nice build ! Congrats :beerchug:
silvalis
by silvalis
I copped a bit of flak in my Tere build thread for keeping the saddle :P
But the shape works well for me and the CRB version only saves 50g for around $350aud...
Chasse patate
silvalis
by silvalis
Now with a zipp speed sl carbon stem 110mm and a zipp sl-70 aero bar 40cm.
And some new tape
Chasse patate
moonoi
by moonoi
silvalis wrote:Now with a zipp speed sl carbon stem 110mm and a zipp sl-70 aero bar 40cm.
And some new tape
I have the same tape, try not to get it wet, since it soaks through and after just one month the surface is separating from the bottom, and the tape no longer sticks...at least in my case anyway....will replace it with something else soon, which is a shame because it looks really great and is comfy too
Sent from my Phone 2 using Tapatalk
silvalis
by silvalis
Yeah ok. Probably won’t last long for me as I noticed it gets dirty easily
I’ll probably put supacaz back later. Or maybe try nalec
Chasse patate
