I was responding to wolfesquire’s post haha. He lives not far from me. I’d love to come check out Singapore though hahacenturionAL wrote: ↑Mon Sep 24, 2018 4:55 pmWow appreciate it... But I'm in SingaporeSpecializedColnago wrote: ↑Mon Sep 24, 2018 3:45 pmLet me know if you need some help on it. I can dig up the buffing kit I used with the various power drill specific buffing wheels and the correct buffing compound for you to borrow.wolfesquire wrote: I think I just found myself a winter project on my CAAD12. Virginia doesn't get horrible winters, but I would rather ride the trainer in front of the TV in the winter than bundle up.
El Cheapo Caad10
Where u from? Do let me know if u happened to comeSpecializedColnago wrote: ↑Mon Sep 24, 2018 5:48 pmI was responding to wolfesquire’s post haha. He lives not far from me. I’d love to come check out Singapore though hahacenturionAL wrote: ↑Mon Sep 24, 2018 4:55 pmWow appreciate it... But I'm in SingaporeSpecializedColnago wrote: ↑Mon Sep 24, 2018 3:45 pmLet me know if you need some help on it. I can dig up the buffing kit I used with the various power drill specific buffing wheels and the correct buffing compound for you to borrow.wolfesquire wrote: I think I just found myself a winter project on my CAAD12. Virginia doesn't get horrible winters, but I would rather ride the trainer in front of the TV in the winter than bundle up.
Lightly sanded down the fork to remove the clearcoat. Sprayed it gloss black
- Moderator
The rough strip looks awesome
Using Tapatalk
Thanks, I have no patience.... Lol
Done! Gg to put on bartape and bottle cages once I have the time. 6.7kg from my mechanic's scale as what he told me.
Your levers are too low, ramps should be parallel with the ground at minimum, higher is acceptable too.
First ride after build. Finished at 6.75kg with pedals.
Is there a reason why one wouldn’t be able to use a chemical stripper to remove the paint from an aluminum frame? I’ve used chemicals to strip the clearcoat/paint from my alloy (car) wheels and polish them up afterwards. It’s much easier than sanding by hand and then you can use a machine polisher to get the final finish you want (brushed, matte, full polish). Like this https://www.flickr.com/gp/7120760@N05/2927u1
A chemical stripper could get rid of those small black marks on the welds of your head tube.
iamraymond wrote: ↑Tue Oct 16, 2018 1:12 pmIs there a reason why one wouldn’t be able to use a chemical stripper to remove the paint from an aluminum frame? I’ve used chemicals to strip the clearcoat/paint from my alloy (car) wheels and polish them up afterwards. It’s much easier than sanding by hand and then you can use a machine polisher to get the final finish you want (brushed, matte, full polish). Like this https://www.flickr.com/gp/7120760@N05/2927u1
I did use chemical stripper but those black marks are super stubborn
What type of stripper did you use? I had very good success with Aircraft remover or 3V3. It might take a few concentrated applications to the difficult areas.
