CX Build: Trek Crockett Disk 2018
Rodigan
by Rodigan
Sold my cross bike and now plan to reinvest in this build; aiming for £1300 and 8.6kg using some parts I already have.
Frameset: Trek Crockett 2018 50cm
Seatpost: Canyon S13
Saddle: Bontrager Race
Stem: Kalloy Uno (90mm)
Handlebar: Zipp Service Course SL80 (40cm)
Pedals: Shimano M540
Wheels: Hunt 4 Season Disk
Tyres: Callenge Limus
Shifters: Ultegra R8020
Brakes: Ultegra R8070
Rear Derailleur: Ultegra RX
Crankset: Ultegra 6800 170mm
Chainring: Garbaruk 40t
Cassette: Sunrace CSRX1 (11-36)
Rodigan
by Rodigan
The Ultegra Rx derailleur arrived yesterday, bang on the money at 242g.
Also received the Garbaruk 40t chainring which came in 1g under the expected weight at 79g. I plan to reuse an old Ultegra chainset which had a buckled chainring - not a perfect colour match but I might look into getting it powder coated black in the future.
Rodigan
by Rodigan
I managed to source a Zipp SL80 handlebar for £45 but unfortunately it came in at a hefty 257g for a 40cm. The drops are quite long on this model so I may remove ~25mm from the bar ends once it's mounted, this will likely give my knees a bit more space when navigating obstacles out the saddle too.
The Uno stem weighs in at 103g with the standard bolts, these will be replaced with Ti bolts before mounting.
sennder
by sennder
Looks great so far! I have been considering a similar Crockett build with Sram Force 1 for a while. Looking forward to seeing how this turns out.
--Sennder
Rodigan
by Rodigan
I almost built this up with SRAM, even ordered some parts, but I had a last minute change of heart and decided to stick with Shimano. I put together a build sheet for it though so this might help if you're interested:
Rodigan
by Rodigan
P.S. The SRAM Force 1 crank is north of 700g for the GXP version so you might want to buy something else to keep your build weight down!
FIJIGabe
by FIJIGabe
Looks like a solid build. I recently rebuilt mine to go 1x, and went with an XT Di2 rear derailleur, since the Ultegra RX stuff wasn't out on the market, yet. I definitely like the chainrings, even though the color is a little off. I used a Wolftooth 38T ring, and had the stock 6800 covers shaved down by 2mm by a machine shop, to maintain the look.
I think you can definitely hit your weight goal, but I would look to replace the saddle. I would also keep the stock steel bolts on the stem, because the last thing you want to have happen during a CX race is to hit a bump and have those bolts fail.
Emonda SLR (under construction), Madone 5, Cobia. I own a lot of Treks.
Rodigan
by Rodigan
@FIJIGabe - Can you post a picture of your chainring? It sounds pretty cool, I like the ingenuity of it.
I'm not overly concerned about the Ti bolts failing as I've been using them for years and I'm tiny! Probably a different story for big blokes or anyone racing enduro though.
The saddle is a hand-me-down from my Emonda so it's free, but I'd love to find something lighter. Any suggestions? I don't want to use anything too high end offroad and it would have to be durable enough for remounts and crashes.
FIJIGabe
by FIJIGabe
Sure, not a problem! Sorry for the dirt on the bike, I haven’t washed it since my last gravel ride (Saturday).
Free saddles are great. Personally, I’ve found great deals on eBay for Bontrager saddles, even high-end one’s. I know the ones I like (Affinity RXL’s for Road, Evoke RXL for Off-Road), and I’ve only ever had a problem with the newer Affinity Pro saddle, and went back to my old RXL.
Good luck on the build. I really need to update my build page with all the new stuff I’ve done to it.
Rodigan
by Rodigan
Nice job man, that looks great! I'll be sure to check out your thread when you update.
And thanks, I'll keep an eye out on eBay.
Rodigan
by Rodigan
Wheels. I was an early adopter when Hunt came on the scene three years ago and these 4 Season Disks are ready to go as soon as the axle adaptors arrive in the post. I dare say I'll lose a couple more grams with a thorough clean too!
Front Wheel.
Rear Wheel.
Freehub
Rear axle: this is the quick release version and will be replaced to fit a 12x142 thru axle.
These front wheel adaptors came with my hoops 3 years ago but unfortunately the standard is now 12mm rather than 15mm so they're no use. Weight for info.
Rodigan
by Rodigan
I ran 160/160mm rotors on my previous bike but with the move to flat mount hydraulics I had a choice: buy and fit an adaptor to run 160mm rear, or buy a smaller 140mm rotor. I went with the latter. Hopefully it's the right option. Again, these need a good clean up before use.
FIJIGabe
by FIJIGabe
At your size, you’ll be fine with a rear 140mm rotor. I’ve been toying with the idea of running the same, since Houston is relatively flat, and I would eliminate the spacers on my calipers.
onemanpeloton
by onemanpeloton
I love the crockett and have been considering one for a while now.
keep up the good work 8)
2017 Giant TCR Disc
2015 Giant TCX
2016 Cube Stereo 140
wpccrunner
by wpccrunner
I just picked up the grey/fluoro 2019 corckett a few weeks ago. Swaped a few parts and now deciding on a whelset, before the season starts. I previously had a 2014 crockett canti
