2016 pearl white Allez Sprint build!
07stuntin6r
by 07stuntin6r
Sock3t wrote:
LocoDuck wrote:
Sat Sep 29, 2018 3:11 pm
But whats the weight? Image
I'd bet 9kg
In stock form this doesnt even weigh 9kg and I've gone lighter.
Sent from my SM-N950U using Tapatalk
Sock3t
by Sock3t
07stuntin6r wrote:
Sat Sep 29, 2018 11:22 pm
I'd bet 9kg
Did you weigh it in stock form?
Sock3t
by Sock3t
themidge wrote:
Sat Sep 29, 2018 3:52 pm
^^ I don't think it'll be that much, probably high 7's or low 8's.
thedonnydino wrote:
Sun May 28, 2017 11:03 pm
Had my Sagan Superstar Allez Sprint built up last week. A bit of a whirlwind build - only saw a photo of it online maybe two or three weeks ago!
ImageIMG_4512[1] by Donny Dino, on Flickr
Build Specs as follows:
- 54cm frame.
- Zipp Service Course SL Stem - 110mm
- Zipp SL70 Bars
- Force 22 Groupset
- Enve 4.5's laced to Ceramic Chris King hubs
- Duraace pedals
- Power Pro saddle (ti rails).
Built weight is 7.5kg, which I am more than happy with as it was never going to be a weight weenie. I intend to race it, and having a tough time rationalising carbon bars and stem. In addition, didn't want to throw too much $ at it (had the wheels already).
OP has a heavier frame (larger size), a heavier groupset, MASSIVELY heavier wheels, heavier pedals, heavier tyres, heavier tape.
07stuntin6r
by 07stuntin6r
- 54cm frame.
- Zipp SL70 Bars
- Force 22 Groupset
- Duraace pedals
Like is said once I get my wheels which are carbon 56mm reynolds with vittoria corsa g, latex tubes. Frame is the same size, I have a s works saddle which is carbon and carbon stem which is lighter than what's pictured. Same bars and for my handlebar tape I have pretty thin fizik wrap. Only thing that would be heavier is the crankset, cassette and pedals.
themidge
by themidge
The frameset must be pretty heavy to begin with then, getting on for 2kg? Anyway, OP, keep upgrading and it'll definitely get a lot lighter :D.
A few suggestions:
-wheels sound good, but veloflex masters are lighter than those vittorias and cheaper as well
-If/when you upgrade the groupset, get Sram, even Rival can be ultegra or dura ace weight if you get some different cranks (which I would recommend anyway, shimano trickles down function and not weight!)
-bar tape can be amazingly heavy sometimes, so try to get some light stuff next time you replace it.
-cables are a good place to save weight, alloy linked housing can save about 50-100g
-buy used stuff to keep upgrade costs down, it's amazing what you can get barely used for a fraction of the new price
07stuntin6r
by 07stuntin6r
themidge wrote:The frameset must be pretty heavy to begin with then, getting on for 2kg? Anyway, OP, keep upgrading and it'll definitely get a lot lighter :D.
A few suggestions:
Yeah I'm really wanting sram force 22 or shimano ultegra not sure yet. I have nice dura ace brakes which weigh very minimal and were a great upgrade from the axis 1.0.
themidge
by themidge
Keep the Dura Ace brakes even if you upgrade to Sram, by all accounts they're better than Sram brakes and should work fine with Sram levers
07stuntin6r
by 07stuntin6r
A few suggestions:
Also the tires and tubes were free from the dealer since they were 2019 wheelsets. Some deal from reynolds.
07stuntin6r
by 07stuntin6r
themidge wrote:Keep the Dura Ace brakes even if you upgrade to Sram, by all accounts they're better than Sram brakes and should work fine with Sram levers
I just like to match haha. Also when it comes to pedals I wanted new dura ace or ultegra but after this weekend I started to wonder rif I should get speed play. All the guys raving kept dragging pedals on this new course they could have in the future
07stuntin6r
by 07stuntin6r
themidge wrote:
Sun Sep 30, 2018 5:19 pm
Would sourcing DA 9000 groupset except brakes (got those) be worth it over a new full Ultegra R8000 group? I can always go with an ultegra cassette and the derailleur seem like I can get them for a decent price. Only thing would be either the crankset or find some lighter crank arms like s-works etc.
themidge
by themidge
DA9000 and Ultegra 8000 are both fine choices. Piecing together a 9000 group right now is probably still going to be more expensive than getting a new 8000 one, but it will be lighter. Your choice :D.
Just a thought: if you were to piece together a groupset, light cranks like sram red or specialised s-works will probably be similar in price to DA, so if you'll sacrifice a bit of brand continuity, that could be a spot to save weight 'for free'.
07stuntin6r
by 07stuntin6r
themidge wrote:
Wed Oct 03, 2018 7:53 pm
Right....I don't mind having s-works cranks it's just finding them for a decent price as they are hard to come by. I almost bought a used force 1 52t crankset, but still didn't know if I wanted to go 1x or not and what it would entail. I live in a flat area for the most part and even on some hills don't even go to my smaller chain ring.
themidge
by themidge
Happy deal hunting :D
07stuntin6r wrote:
Wed Oct 03, 2018 8:15 pm
You can run 1x with a '2x' crank by just changing the rings, so you can always convert from 2x to 1x in the future. It's impossible to do the opposite if you start with a 1x specific crank.
07stuntin6r
by 07stuntin6r
themidge wrote:Happy deal hunting :D
But isnt for instance sram 1x better cause of the chainring tooth profile and bow the rear derailleur keeps more tension on the chain...
Sock3t
by Sock3t
Why is it that you have your own thread? Why can't you just post in the specific Allez Sprint thread?
