2016 pearl white Allez Sprint build!
SpecializedColnago
by SpecializedColnago
You need the 7mmx9mm saddle rail clamps for the carbon railed specialized saddles. The Allez comes stock with the 7mm round rail clamps. Depending on how hard you tightened the saddle rail clamp down you may have cracked the carbon saddle rails and it may not be fully seated in the clamp. Both of which would be bad.
mattr
by mattr
07stuntin6r wrote:
Sun Sep 23, 2018 4:50 pm
Didnt known I needed those. You mean oval mounts?
Sent from my SM-N950U using Tapatalk
Changed your tone pretty quickly there......... :roll:
07stuntin6r
by 07stuntin6r
SpecializedColnago wrote:You need the 7mmx9mm saddle rail clamps for the carbon railed specialized saddles. The Allez comes stock with the 7mm round rail clamps. Depending on how hard you tightened the saddle rail clamp down you may have cracked the carbon saddle rails and it may not be fully seated in the clamp. Both of which would be bad.
Just swapped the seats out, no damage. I tq all my stuff to spec.
mattr
by mattr
Doesn't matter if it's torqued to spec if it's the wrong shape/size.
SpecializedColnago
It wasn’t a question of torque, it’s the question of an oval rail fitting in the round form of the stock 7mm saddle clamp and the associated stresses created by it.
07stuntin6r
by 07stuntin6r
SpecializedColnago wrote:It wasn’t a question of torque, it’s the question of an oval rail fitting in the round form of the stock 7mm saddle clamp and the associated stresses created by it.
I was stating I tq'd to spec because you asked if about how much I tightened the clamp.
07stuntin6r
by 07stuntin6r
Just ordered...guess I'll try it out next weekend.
Sock3t
by Sock3t
Why not buy from you LBS?
07stuntin6r
by 07stuntin6r
Sock3t wrote:Why not buy from you LBS?
Because they would have to order it and I wanted it sooner than they could get it for me.
LocoDuck
by LocoDuck
But whats the weight?
07stuntin6r
by 07stuntin6r
LocoDuck wrote:But whats the weight? Image
Once i find a scale I'll get one.
Sock3t
by Sock3t
LocoDuck wrote:
Sat Sep 29, 2018 3:11 pm
I'd bet 9kg
07stuntin6r
by 07stuntin6r
I'd bet 9kg
I got reynold carbon wheels coming prob check it than.
07stuntin6r
by 07stuntin6r
Next thing I'd like to do is go 11spd. Just dont know if I want Sram force 1x, keep shimano and find dura ace 9100 crankset/Dr's or go with the whole new 105 or ultegra group.
