Ryan's Forever Bike: A Litespeed T1sl #tongue-in-cheek
RyanH
by RyanH
@chris
Yeah, if you have a metal spindle THM crankset then just use the SRAM PF30 one. Same idea as the BB386 Quarqs, everyone just runs those with a regular PF30 bb and spacers. The benefit of the SRAM one is that it's delrin on the outside and there's a sleeve that goes over the spindle between the bearings, so not metal on metal contact. I don't think I've ever had a SRAM PF30 bb creak on me, can't say the same for nearly everything else including Chris King.
@romanmoser
Yeah, they emailed me about it but the pictures didn't really illustrate what they did....and it's a disc only frame so that's a bit of a non-starter for me.
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
leicaman
by leicaman
Denavelo wrote:
Thu Nov 01, 2018 6:48 pm
Interesting..... The SRAM PF30 BB will work fine with (THM) cranks? I'm getting a nasty click on my Firefly and THM PF30 BB + M3 combo. When I built the bike, it was mute silent, but that was nearly 6 months ago. I see the THM bottom brackets have the bearings outboard more so than the SRAM.
I would love PF30 BB suggestions.. Ti frame noises drive me nuts.
I’m not familiar with the THM cranks but whenever I install a PF BB, I always use wakos brake protector. I’ve used it in my old carbon frames, a steel Niner RLT and with my new Litespeed T2. Never had one creak from any of them. Not sure if you can get hold of the wakos stuff where you live but it’s easy to find here in Japan.
RyanH
by RyanH
I wasn't planning on doing any changes this weekend since I'm trying to wrap up a huge project but since I woke up at 3:15am this morning and after unsuccessfully going back to sleep, have been working since about 4am, I decided I'd give myself a break. I glued some Extremes on the Lightweights (pair #2) and installed the Carbon Ti rings (shout out to dmoneysworks for the quick shipping). Dropped about 250g which puts the bike around 5.9kg. Not terrible for a metal bike with 9100 brakes and a tad porky PM (Sisl2 SRM is about 100g lighter with MKV rings).
I ordered 4 tires, these two ended up being the lightest I've gotten in awhile:
52/36 Carbon Ti ended up saving 75g:
Not too shabby:
Strava
KCookie
by KCookie
Wow, those tyres are light. Your so bloody lucky. Mine were 240.9 and 248.7. What was the weight of the other two. Were did you get them from. I'm never that lucky.
Sent from my SM-G960F using Tapatalk
RyanH
by RyanH
@KCookie
The other two were 242 and 243g. I got them from Merlin.
Here's a snap in the current getup:
Strava
romanmoser
by romanmoser
fap fap
spdntrxi
by spdntrxi
let us know how the shifting is with Carbon-Ti
JerryLook
by JerryLook
What kind of mileage are you guys getting out of the Veloflex extremes? Merlin states 6000km front and 3000km rear. Are you guys getting that many miles out of a pair?
2010 Orbea Opal 54cm
5.97kg
RyanH
by RyanH
I got 2200 miles out of my last rear tire before it was worn through.
Strava
JerryLook
by JerryLook
Wow that’s pretty good
5.97kg
dereksmalls
by dereksmalls
That is a beautiful looking bike Ryan
dgasmd
by dgasmd
RyanH wrote:I got 2200 miles out of my last rear tire before it was worn through.
I used Veloflex only for a long time and would get 1600-1800 max, but I suspect I’m nowhere near as light as RyanH. By comparison, I used to get 1800-2000 from Vittorias, and now get regularly 2200-2600 from Continental Competitions. Front I’d get 6000+ miles regardless of brand and type.
RyanH, that bike is badass AF!!!!
dgasmd
by dgasmd
RyanH wrote: Image
Pardon my ignorance, but can you point me to where I can learn more about the chainrings and the options? What kind of mileage on can expect, costs, limitations, etc
RyanH
by RyanH
It's the only light option for 4 bolt. I think they're heavier than Cannondale MKV in standard and compact but there's a lot more options. Details on them are sparse, so I'll report back as I use them. I need to fine tune my FD because it threw the chain using the position that the BOR 53t rings were at (this is 52t). I had to bring it in a little and now it's rubbing in small/<20t in rear. Hopefully it's just an alignment issue with the FD.
Cost is astronomical for new ones, I was fortunate enough to pick these up second hand, but even used they're almost more than Fibre-Lyte new. The inner ring is not much lighter than alloy so you can save a lot by using a regular alloy one.
Strava
mrlobber
by mrlobber
Word of caution: I've seen a Carbon-Ti outer being destroyed on a normally shifting Etap setup while shifting from small to big under mediocre power. One of the pins "bonding" the outer teeth to carbon spider was ripped out and subsequently the ring failed.
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
