Godzuki26 goes pink - Litespeed T1SL but first a 4.05kg Scott Addict R2
godzuki26
by godzuki26
A titanium M6 bolt is a little bit lighter.
:arrow: BH Ultralight
:arrow: Litespeed Ghisallo
ImageCannondale Evo HiMod
ImageFelt AR FRD
godzuki26
by godzuki26
But I need a hollow titanium bolt and I found some on Ebay made by RISK. They came in a cool looking jewlery box too. Made me tingle inside. :unbelievable:
ImageFelt AR FRD
godzuki26
by godzuki26
One tip for using your own bolt with these Schmolke clamps is making sure the M6 bolt is not too long. If you are not careful and the bolt is too long, you will tighten the bolt directly into your carbon handlebars which will cause it to crack. Thus, I had to shorten these titanium bolts by about 1mm and almost started a fire because titanium does not like power tools. I saved around 11 grams in the end.
ImageFelt AR FRD
spdntrxi
by spdntrxi
all this talk about not taking risks.. and he's using bolts called "risk" :noidea:
godzuki26
by godzuki26
@spdntrxi - LOL....I did not even realize that. Probably one of the worst names a company can use for light weight after market parts. Almost as bad as marketing a line of components labeled "CRASH"
ImageFelt AR FRD
burglarboycie
by burglarboycie
Man this is an exciting thread already!
Klaster_1
by Klaster_1
Those hollow Ti bolts are trick, I got something similar for my stem too. Wonder if it would really be a good idea to use these in such critical places as shifter clamps and disc calipers.
rlpaul
by rlpaul
You got 18mm bolts?
godzuki26
by godzuki26
Yes they are M6 x 18mm. I am not too worried with these bolts because they are made of titanium. I would definitely be concerned if they were aluminum. The only issue is galvinization between the Ti bolt and Ti shift clamps. I was sure to use plenty of TiPrep on the bolt threads.
ImageFelt AR FRD
godzuki26
by godzuki26
I have to do a little tuning. Carving out material from a top cap will not do anything for performance. The Tune topcap is meaty. The logo also needs to come off. I do like that it is UD and will match the Ax Lightness stem.
ImageFelt AR FRD
godzuki26
by godzuki26
Stock Tune Aluminum bolt vs nylon bolt vs Schmolke carbon bolt........The nylon bolt prevails.
ImageFelt AR FRD
godzuki26
by godzuki26
It matches. But wait, those silver titanium bolts are annoying to the eye.
ImageFelt AR FRD
RyanH
by RyanH
Or you could've just gotten the extralite hyper cap:
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
godzuki26
by godzuki26
I won't be able to ride and stare at those distracting silver bolts. They will reflect from the sun and blind my eyes causing me to crash. I had to replace them with black titanium bolts. The four face plate bolts are M4 x 20 and the two steerer tube bolts are M5 x 20.
ImageFelt AR FRD
godzuki26
by godzuki26
@RyanH - but there is a girl on the top cap and that will distract me while riding like the silver bolts. :D
The Schmolke bar plugs look cool and match the handlebars. It almost looks like one piece. I got the option "no bar tape" when I purchased these. I may leave the drops tapeless but that defeats the purpose of making a comfortable/rideable bike. If I start steering in that direction someone please tell me to stop!!!! Don't let me turn this into another hang it in the garage and stare at it bike.
ImageFelt AR FRD
