Colnago C40 Mapei
Bely
by Bely
They don’t make them like they used to....
Current
S.V | Argo2.0 | Cherubim | Festka Scala | Pego Respo & Marcelo | VXRS | 07 Trek Mad Sl | Merckx TSC | English V3 | Colnago C40 Mapei, C50 WC, C59 Saronni, C60 Italia, C64 Art Decor, Field
Incoming
Tsubasa, Aero Road Bike
mattyNor
by mattyNor
Is that brake bridge rivited to the frame??
Sent from my SM-G930W8 using Tapatalk
garjo
by garjo
best paint-scheme ever
My 4,93 kg Supersix Evo HM: viewtopic.php?f=10&t=137647&start=30
My 6,22 kg Cannondale R500 1996: viewtopic.php?f=10&t=134364
Geoff
by Geoff
Ok, that's nice. Make sure that you build it up as vintage!
Calnago
In Memoriam
by Calnago
I’ve never seen a riveted brake bridge like that on a C40. Any info?
Also, that seattube extension above the seat clamp... is that some kind of sleeve or something? Never seen that either.
Wingnut
by Wingnut
mattyNor wrote:
Tue Jul 31, 2018 1:10 pm
Something I really dislike about Colnago's...for the high end price I would have hoped and expected something better than rivets.
Calnago
In Memoriam
by Calnago
@Wingnut, you kind of imply that you’ve seen those rivets before on other Colnagos? I haven’t. What year/models did they ever use those if it’s part of the original bike? It looks like it may have been a repair of some sort. I don’t know. I also have never seen a sleeve protruding above the seat collar, which looks like alloy, not carbon.
Konsta
by Konsta
That ”sleeve” is a seatpost shim. Most likely manufactured by USE in UK.
Cheap and very well made items indeed. https://ultimateuse.com/spares-and-acce ... post-shims
themidge
by themidge
^ Now you say it, it all makes sense :D.
Quite why you would use (hehe!) a shim in a C40 frame I don't know, it takes a 27.2mm post right?
jekyll man
by jekyll man
Calnago wrote:
Wed Aug 01, 2018 2:56 pm
As Konsta says- USE shim.
As for repair; my 1998-9 C40 had those rivets. Only difference was they were painted.
themidge wrote:
Wed Aug 01, 2018 5:21 pm
Nope 27.0mm or was it 28.0?
Back on track. Bely another nice one :thumbup:
Official cafe stop tester
Calnago
In Memoriam
by Calnago
Thanks, so Colnago did produce a C40 with a riveted brake bridge then. I did not know that.
Yes, about the shim... I see that now. Looks to be a nicer quality shim than the ones I’ve seen, which sometimes amount to nothing more than a piece of beer can cut to fit. The nominal size for the seat tube in the C40 was 28.0, at least the ones I’m familiar with. So this shim must take it down to 27.2mm, which was a much more standard size to find.
C36
by C36
Calnago wrote:Thanks, so Colnago did produce a C40 with a riveted brake bridge then. I did not know that.
http://www.oldbici.it/tag/colnago/
Here Tom Steels bike, not super clear but see the rivets on 2 pictures.
mrfish
by mrfish
My 1999 C40 has rivets too. I’m guessing they just held the bridge in place while the epoxy dried as it does seem a strange way to fiy
Seatpost is 28mm, originally they did a carbon post with embossed club typically gold, later a sticker under clearcoat.
glepore
by glepore
My MkII doesn't but the bridge looks similar. Wouldn't be surprised if they ground them down and covered with filler for appearance.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
