Colnago C50 World Champion
pritchet74
by pritchet74
:popcorn:
Have you ever wondered if there was more to life, other than being really, really, ridiculously good looking?
Bely
by Bely
Little by little...
Current
S.V | Argo2.0 | Cherubim | Festka Scala | Pego Respo & Marcelo | VXRS | 07 Trek Mad Sl | Merckx TSC | English V3 | Colnago C40 Mapei, C50 WC, C59 Saronni, C60 Italia, C64 Art Decor, Field
Incoming
Tsubasa, Aero Road Bike
dudemanppl
by dudemanppl
Shifter position needs to be moved up a few cm :(
themidge
by themidge
^ ditto, and bars could do with being rotated down quite a bit too. The rest looks awesome though, I'd go as far as to say it's the best Bely build yet (with either wheels) :thumbup:.
Calnago
by Calnago
At the risk of not knowing if that is intended to be your final setup or not, it’s gotta change, cuz that is horrible as it is.
Three things to fix it:
1) rotate bars down so that the flat part of the drops are parallel to the stem.
2) move the levers up the bar so that the tips are level with a line extending forward from the bottom of the drops. Many modern bars this guideline does not apply to, but I think with these bars it would end up perfect.
3) reroute the derailleur cables (if possible) so that they go over and around to the front of the bars. This is a much more relaxed route versus the acute bend that is necessary if you use the alternative routing to the back like I think you have it there. Ultimately, that acute bend there will cause the cable to fray, much like the dreaded 90 degree bend out of Shimano levers does. Even if there is an intended internal routing hole at the back, I would bypass it if it meant you could run the cables to the front. Also, brake housings behind the derailleur housings up front. It will make the finishing touches and cable routing easier to get right and much more functional in operation (no cable housings pushing on one another as you turn).
It’s gonna be nice. Do you find you need a zero setback post? I’m presuming you do, but I think zero setback posts are way overused, except for frames that are designed for them, which this is not. Very few are actually designed with a zero setback post in mind as the default. One frame that is/was is the Cervelo RCa. It has a slacker seattube than would otherwise be used in a similar size frame, which effectively creates a built in offset. Of course, if your body type is far from normal and you really require it that’s different, but that should be the exception, although you might not know it given how many people think a zero setback post is right for them.
MayhemSWE
by MayhemSWE
Calnago wrote:
Sun Jul 22, 2018 6:00 pm
Not sure why you're bringing this up at all? The seatpost clearly has plenty of setback, if not obvious from the photo on this page then definitely in the photo on the first page…
Calnago
by Calnago
^you are absolutely right, my bad. From the pic on my phone I couldn’t tell that it is in fact the original Colnago post in there (I couldn’t see the setback) so thanks for the correction.
rexyi1990
by rexyi1990
beautiful!
Bely
by Bely
Current
Incoming
dudemanppl
by dudemanppl
shifter angle still bunk and needs black tape :( then it'll be PERFECT
themidge
by themidge
I think the tape is alright, it goes with the white front of the frame. And it's a bit retro to black saddle and white tape, so I think it's cool :D.
But yeah, except for the cockpit angle, 10/10 would smash :thumbup:
by 9734344
It might just be it's not Campag 10sp. sorry.
Bely RULES!
I'm not a NUMBER.........I'm a Free Man
dj97223
by dj97223
Love this bike. :thumbup:
Haydn
by Haydn
Perfect!
