JROY's Bicycles
jroy
by jroy
This will be my thread where I put my bicycles, parts, thoughts, and maybe some discussion.
Unfortunately, I lack proper weenie-ing and will at some point look to rectify that, for now it'll just be some bikes.
And now I present my RD#2
Yes it is 7,420 grams. The frame with hanger and bottle mounts is 1072 grams, which I am pleased with for my second frame.
  • ITEM MAKE MODEL/YEAR DESCRIPTION WEIGHT(GRAMS)
    FRAME Homemade proto # 2 1072
    FORK Enve cut with crown race 315.42 (-10.61race) 304.81
    EXPANDER Carbon-Ti 13.7
    HEADSET Canecreek 40 83.05
    TOP CAP Absolute Black 3.66
    STEM Kalloy Fairwheel bikes edition with black titanium bolts 105.37
    HANDLEBAR Easton EC70 42cm width 226.58
    TAPE Fizik total tape (75.85 need to cut to length) 75.85
    END CAPS Fizik 5.95
    FRONT WHEEL (with rim strip) Easton EA90 Limited Edition with rim strip 625
    FRONT RIM STRIP
    FRONT AXLE Easton EA90 Limited Edition 58.9
    FRONT TIRE Michelin Krylion endurance 25cc wide 255.24
    FRONT TUBE generic 10.12
    REAR WHEEL (with rim strip) Stans Notubes Alpha 340 with rim strip 812
    REAR RIM STRIP
    REAR AXLE Stans Notubes 60
    REAR TIRE Michelin Krylionendurance 25ccwide 253.72
    REAR TUBE generic 90.95
    FRONT BRAKE Shinamo Ultegra 159.06
    FRONT CABLE/HOUSING Jagwire
    REAR BRAKE Shimano Ultegra 157.56
    SEATPOST Woodman titanium hadware topper 89
    SADDLE Selle San Marco Aspide FX Carbon 134
    SEAT CLAMP N/A does not need
    BOTTOM BRACKET Wheels MFG PF30 Shimano Rotor compatible thread together inside 156.9
    CRANK ARM (SET) P2M Rotor 3D +P2M classic 130mm BCD 895
    CHAIN RING Praxxis Works 53/39 standard included with cranks
    PEDALS Look Keo Blade Carbon 226.63
    FRONT MECH Shimano Ultegra 6800 10 speed 100.6
    SHIFTER Shimano Ultegra 6800 shifter 197 + hoods 221.03
    CABLE/HOUSING
    CHAIN Sram PC-1071 246
    REAR MECH Shimano Ultegra 6800 RD=182 +KCNC pulleys 14 196.71
    SHIFTER Shimano Ultegra 6800 shifter 195 + hood 220.09
    CABLE/HOUSING
    CASSETTE Sram PG-1070 11-25t cassette 235
    BOTTLE CAGE (DT) Elite Custom 42.65
    BOTTLE CAGE (ST) Elite Custom 42.62
    COMPUTER MOUNT K-Edge Out Front Garmin model 30.85
    SADDLE BAG
    MINIPUMP
    TIRE LEVERS(2)
    SPARE TUBE
    MULTI-TOOL
    TOTAL TOTAL WEIGHT: 7210.6
    ACTUAL MEASURED WEIGHT: 7420
Klaster_1
by Klaster_1
Can you tell more about the frame building process? Did you source the tubes elsewhere and only made made the small parts like dropouts?
jroy
by jroy
Yes the tubes are sourced elsewhere. There are quite a few options, I went with Rockwest. Due to the tubes being stock and designed for wide applications they would seem to be overbuilt and a reasonable amount of weight could be taken out of them with a different layup schedule. This is something I'm working on.
I make the dropouts, first by making a thick plate and then cuting out the dropout. The hanger is from Paragon Machine Works.
From there it is simple tube-to-tube construction with coping and fitting tubes on my jig and then tacking them together. After that I over wrap the joints and vacuum bag.
This is my second frame and quite an improvement over the first. There are still lots of things I'm looking to refine. The next frame build is a cyclocross/all-arounder.
rexyi1990
by rexyi1990
Wow, that is awesome!
NiFTY
by NiFTY
Impressive work but that handlebar position is very wrong.
jroy
by jroy
A nice little weight savings: before and after
Gotten in a beer trade from someone who prefers 11-28t.
I also made a saddle combo to test out my new saddle mould. Modelled off a Fizik Thar. This is going on my dirt jump bike, which is rather different from bikes typical of this forum.
What it is replacing
On the DJ bike
Kimmoth
by Kimmoth
Nice work!
Hard to see where all the weight's coming from, though... your frameset, bars and wheelset weigh about the same as mine, but I'm 3/4 of a kg lighter.
Must be that I've got Red instead of Ultegra and no power meter... I guess segmented cable housing helps a bit too.
jroy
by jroy
Thanks.
The powermeter, crank arms, and chain rings weigh 895 grams. Red is probably around 600 depending on year and chainrings. Everything on Red is 30 to 80 grams lighter, which add up. My cable/housing is Jagwire Universal Sport brake and shifting, although I didn't weigh it, I'm sure it's not light.
jroy
by jroy
A small low quality image preview.
BmanX
by BmanX
Following. Love this stuff.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT for 2 decades
nestornnk
by nestornnk
Great effort and result.
I really admire your talent and passion..
Very nice frame
How it rides?
jroy
by jroy
This second bike rides decent, better than my first build. I need to do more developing of the layup and processing for the joint wrapping. The geometry is where the bike excels, in my opinion, in terms of ride.
I'm just starting to get into developing a third frame and will be trying to better document and share it here.
jroy
by jroy
Since all my previous pictures are also awful, I'll just keep using that quality, sorry.
Lynskey GR270 gravel bike.
rexyi1990
by rexyi1990
Wow, cool!
jroy
by jroy
Some new improvements machined for the frame jig.
A new brake bridge fixture fabricated.
Foam core sandwich panel for chain stays.
The new road frame.
Soon to be painted by mediocre painting talent. Then, build to follow.
