Internally Geared (IGH) XC FS Experiment
- andreszucs
- in the industry
Let's see how light I can put this together, I'm converting my beloved 2011 Scott Spark from RD/Cassette to IGH, should have this done in a few days and I'll post here final pictures.
Just a quick pic of the WIP with some clues
btw...I'm sure this post is a 'hater's bait' by default, so please backup you comment answering if you actually have tried the hub before.
My stuff on sale https://www.ebay.com/sch/andreszucs/m.h ... pg=&_from=
- andreszucs
- in the industry
Yeah I've gone towards the same questions, I 'think' IGH is overlooked in many ways, so instead of searching online for references I decided to put one together and see If can get performance out of the idea based on low weight and all the good stuff a FS bike can offer.
- andreszucs
- in the industry
What made you go back? Hub failure?
- andreszucs
- in the industry
Until now, I never really found a good justification to use Di2 shifting on Cassette/RD, I always found overkill to add complexity, batteries, high dollar onto something that is hanging outside the bike, fragil and prone to failure, than I tried the Di2 on Alfine. Check out this shifting speed comparison:
Between 0.7s and 0.8s to shift up or down on a 8speed setting (I made this video)...so is safe to assume about 1s on a 11 speed setting.
https://vimeo.com/264469001
Between 2.5s and 2.9s on a Dura Ace Di2 R9150:
https://www.youtube.com/watch?v=9LMjkphpIIM
AND....we can do stationary shifting, huge benefit!
- andreszucs
- in the industry
Mind me asking If you know of compelling reasons to rank the Rolloff above Alfine? It seems to me that Rolloff gained popularity because it use to have more gear range compared to the Alfine, but now that they have a 11sp version (higher than a 11-42 cassette) is there anything else superior on the Rolloff? Weigh is similar, same sort of engineering inside, does it handle more torque than Alfine?bm0p700f wrote:All I'm going to say is rolloff. Otherwise the whole idea is a fine one.
I’d say having the Di2 on the Alfine would make it better than Rolloff...also price, Alfine is over 1/3 cheaper!
- andreszucs
- in the industry
Playing around, nylon body with carbon cage for the chain tensioner, should be light if this works.
Weight, and the hub just didn't feel right under power. Might have been an issue with the out-of-spec low primary drive.
- andreszucs
- in the industry
Can’t quite see on the picture, was that a Alfine or Rolloff?Marin wrote:Weight, and the hub just didn't feel right under power. Might have been an issue with the out-of-spec low primary drive.
