Introduce my new Project SL — 4.89kg custom painted FUJI Altamira SL
rexyi1990
by rexyi1990
#CATCH ME IF YOU CAN#
Hello guys, this is my first topic post on WW, and I am glad to share my new "PROJECT SL" to you all. The frame is 2013 Fuji altamira sl (yes, the old TOP line version of FUJI), and the paint job is designed by me (although not painted by me). The project showed in the picture with ax-lightness wheelset is a "just so so" result—4.89kg, and I find that there is still some place for me to upgrade to save another 100g maybe. No more words to say, just look at the picture! Thank you!
yes, I have two climbing wheelset, one is MCC 24, the other is ax-lightness u24t
CATCH ME IF YOU CAN!!!
And final, the weight:
rexyi1990
by rexyi1990
Items
Frame: Fuji Altamira SL, C15 ultra high-modulus carbon w/ High Compaction Molding System, integrated head tube w/ 1 1/2" lower, oversized PIIS BB86 shell, size M/L
Fork: Fuji FC-330 carbon monocoque w/ tapered carbon steerer & carbon dropout
Headset: Extralite UltraTop 41-42 HD & Extralite UltraBottom 51-52
Stem: AX-Lightness Rigid, 6° 31.8mm 100mm
Handlebar: AX-Lightness AX4200, 42cm C-C
Tape: Bike Ribbon Eolo Perforated Techno bar tape
Front brake: AX-Lightness AX3000
Rear brake: AX-Lightness AX3000 (Currently is Ciamillo Gravitas, and I will change it to ax3000)
Front derailleur: Sram Red 22 Yaw, w/ Carbonice chain catcher (Currently is SRAM chain catcher, and I will change it to the carbonice one)
Rear derailleur: Sram Red 22, short cage, w/ Tunning Pedals pulleys & J&L cage
Shift levers: Sram Red 22 DoubleTap
Cables: Jagwire road pro link, w/ KCNC Ti Telfon Coating Brake cables & Power Cordz Shifter cables
Cassette: Recon RHG-RS11AL, 12-27t
Chain: KMC X11SL Ni-Ti plated, gold
Crankset: THM Carbones Clavicula SE 110bcd 172.5, w/ SRAM Red chainring-set 50/34 T
Bottom bracket: THM Shimano Pressfit
Pedals: Speedplay ZERO Ti
Wheelset: AX-Lightness Ultra Road 24 Tubular / Corima MCC S+ 24 Tubular
Front tyre: Tufo Elite Jet <160 g 28"/20 mm black/black
Rear tyre: Tufo Elite Jet <160 g 28"/20 mm black/black
Saddle: Rie:sel Design stu:hl carbon
Seatpost: AX-Lightness AX2200, ø31.6 320mm
Bottle cages: TUNE Wassertrager 2.0
spdntrxi
by spdntrxi
nice !
where did you get those sleeve looking dohickie on the end of the crank arms... I'd be interested
rexyi1990
by rexyi1990
spdntrxi wrote:
Tue May 08, 2018 3:50 pm
nice !
Hi, the sleeve is used for protect the crank arms, because I am from China, I got them on "Taobao.com", but you can also get them on eBay, just search for "crank arm protector"
themidge
by themidge
Nice build, the paint looks very professional. You've achieved an impressively light weight with all those expensive parts, which of course are part of the parcel, but do you plan on doing any tuning? I suspect you might be able to drop quite a few grams with some modifications to some of the heavier parts like the shifters and FD.
rexyi1990
by rexyi1990
themidge wrote:
Tue May 08, 2018 4:31 pm
Thank you very much! Currently, I am not plan to do the tuning job, because there may be other ways for me to drop the weight. The frameset is 950g and the fork is 320g, if I change the frameset to Fuji sl ( or Focus izalco max, Trek emonda slr, Cervelo Rca, etc.), I can drop 300g immediately, the chaingring I used before was Extralite Octaramp RC2, which is 60g lighter than the SRAM, but I choose the SRAM because the Extralite can't be as rigid as it. Tuning is a high-grade job, if I have all the part changed into the lightest one, maybe I will do it to gain further result, but for now I still want the bike to be a daily bike, and some time a racing machine, so I think it may not be necessary for me to do the tuning now.
wheelbuilder
by wheelbuilder
Nicely done!
ak47
by ak47
Ver ynice attention to details! I really like the look of the 32 MCC Corima's!
Vuong05
by Vuong05
Very impressive build!
Current Stable. Evo (Storm Trooper) : 5.39kg | Alchemy Eros : Heavy (7.25kg)
rexyi1990
by rexyi1990
ak47 wrote:
Tue May 08, 2018 9:26 pm
yes, MCC 32 is a great wheelset, good at climbing, while easy to cruise
SuperflyRick
by SuperflyRick
Can you buy those chainstay protectors somewhere they look awesome. Bike looks great too 👍
rexyi1990
by rexyi1990
SuperflyRick wrote:
Sun May 13, 2018 8:39 pm
Hi, it's Rie:sel Design, you can get it from starbike.com! Very nice chainstay protectors, you won't be regret for using it!
