2017 Cannondale SuperSix EVO Hi-MOD 5.56 Kg ( Pics on first page)
Hennesy
by Hennesy
Got a killer deal on a SuperSix Evo Hi-Mod frame and I couldn't refuse. This is my second road bike, my first one was a Caad 12 (6,62Kg). With this project I want to build a bike under 6KG. Maybe it will be between 5.5 and 5.7 KG, a little bit heavier if I will install the power meter.
I'm still deciding which groupset to install ( eTap vs Da Di2) and which crank. For the other parts I will go on MCFK, Extralite, Carbon Ti, Look, Deda Elementi, Veloflex and maybe a Berk saddle instead of San Marco. For the wheels, i ordered a tubular wheelset from an artisan in italy, they will be under 1050 Gr.
Well, now it's time to show some photos.
Hennesy
by Hennesy
With Lighweight set:
With Spacebike wheelset:
Hennesy
by Hennesy
The weight frame is875 Grams, including the BB30.
It's a bit heavy for a 50" frame. :unbelievable: :noidea:
Ceramic BB30 Bearings 40 Grams.
The fork weight is 262 Gr including the original Expander. Probably I will cut a part for saving other grams.
I already changed the original bottle cages's bolts with aftermarkets Carbon Ti Ergal screws. The weight saving was 4 Grams.
The original ones
Carbon Ti Ergal
garjo
by garjo
nice frameset, i'm looking forward to see the complete build
My 4,93 kg Supersix Evo HM: viewtopic.php?f=10&t=137647&start=30
My 6,22 kg Cannondale R500 1996: viewtopic.php?f=10&t=134364
by 573
Hennesy wrote:
Tue May 01, 2018 4:58 pm
This gloss black and chrome Hi-Mod always weighs up heavy. The paint must be very thick; it has to weigh ~120g+.
Peeza21
by Peeza21
This should turn out real good! Looking forward to it
Cannondale Supersix Evo HiMod 2012 viewtopic.php?f=10&t=148290
Cannondale Caad12 2017 viewtopic.php?f=10&t=143217&p=1389852#p1389852
Hennesy
by Hennesy
573 wrote:
Wed May 02, 2018 12:47 pm
Damn, before buy this frame I was thinking it was 750 Gr.. I was a little bit confused when i saw the real weight.. Anyway I hope to make a light build without cares about these 120 grams.
Hennesy
by Hennesy
garjo wrote:
Wed May 02, 2018 9:52 am
Peeza21 wrote:
Wed May 02, 2018 1:17 pm
Stay tuned :beerchug:
Hennesy
by Hennesy
Sram Red Brakes without pads:
Corima 2.0 Pads for Carbon rims:
Hennesy
by Hennesy
Sram red cassette XG1190 11-28:
KMC X11-SL Chain:
Hennesy
by Hennesy
Extralite Hypersteam 110mm 6°:
Deda Elementi Superleggera RS LTD 420mm, It should be compatible with EW-RS910 Juction inside handlebar.
alexgodmar
by alexgodmar
Can't wait to see more!
Hennesy
by Hennesy
Just sent an email to MCFK to know if the seatpost is compatible with DA DI2 BT-DN110 battery. Hope to get a positive response, if not I need to change seatpost (Enve o Save) or choose etap instead Shimano dura ace.
DamonRinard
by DamonRinard
Most 25.4 mm seat posts ID are a close fit with a Di2 battery. Two O-rings with about 10% compression work. (Specific size depends on the ID of your seat post.)
Put the O-rings on the battery: one in the middle and one on the far end (not in the groove). Then push the battery into the post. Let the O-rings "roll" along the battery. Don't push it in too far, you want something to grip when you remove it.
O-rings also let you cut the seat post shorter if you like.
Damon Rinard
Engineering Manager, Road Bikes
Cycling Sports Group, Cannondale
Ex-Kestrel, ex-Velomax, ex-Trek, ex-Cervelo
Hennesy
by Hennesy
DamonRinard wrote:
Thu May 03, 2018 12:31 am
Thanks a lot! This is really a nice idea.
On my Caad12 i have cut my seatpost ( Hylix), the weight was very awesome, about 115 Grams. Maybe i will cut too the MCFK for saving some grams. I found a good deal on a 25,4 x 420mm.
