The frist post in WW & a Titanium road bike 5.485kg with full specifications list
Klaster_1
by Klaster_1
What sort of shrinkwrap did you use? How's the lever body feel?
4ibanez
by 4ibanez
It looks like you'll need to cut some heatshrink away from the shifter paddle in order to shift unimpeded. Another 0.1g to be saved 😉
It looks nice and smooth, but a bit chunky around the shifter body (especially at the top). Is it fully shrunk yet?
YangZili
by YangZili
Leviathan wrote:
Sat Aug 25, 2018 8:41 am
Great work, some really nice touches and Im loving the polishing - but are you planning to polish the whole frame?
thanks, i think i will polish the whole frame when I feel it's hard to be sub 5kg :twisted:
YangZili
by YangZili
godzuki26 wrote:
Sat Sep 01, 2018 5:39 am
Hey man. Good job with the bike and the tuning :thumbup: Keep it up. I like what you did with the bar plugs. That takes a steady hand and some skill :thumbup: I would like to hear more about the shrink wrap. Maybe some more pics. I think it looks cool.
@godzuki26 Wow, Master! I like your works very very much, I learned a lot of skills from your posts,but i have not too much tools. Thanks,i will keep it up!
the shrink wrap is used to cover a fishing rod,I don't know it's brand,It's diameter is 50mm,here it is:
YangZili
by YangZili
Klaster_1 wrote:
Sat Sep 01, 2018 7:57 am
I feel ok,if it's not comfortable ,just wear gloves;it's a no brand Chinese product used to cover the fishing rod,didiameter 50mm
Klaster_1
by Klaster_1
YangZili wrote:
Mon Sep 03, 2018 4:48 am
I wonder if it would fit Shimano levers. How much you saved compared to stock hoods?
YangZili
by YangZili
Klaster_1 wrote:
Mon Sep 03, 2018 5:28 am
I think there is no problem to fit Shimano levers;the Sram RED original hoods is 45 grams and this one is 20 grams.
YangZili
by YangZili
4ibanez wrote:
Sun Sep 02, 2018 9:17 pm
thanks! i will try to cut off some of the heatstrink ,i'am not sure it's fully shrunk,because i have no heat gun and i just use a lighter to heat them,it may not heated evenly.the specifications says it can shrunk to half.
by the way,I like your 4.42Kg Cannondale! :D
4ibanez
by 4ibanez
YangZili wrote:
Mon Sep 03, 2018 6:26 am
Thanks. Heat gun is the best option. Mine aren't perfect, but better than the 1st attempt...
You can see with the RH shifter where I had to trim away a semi circle shape to accommodate the shifter action for a triple downshift.
Great build btw 👍
YangZili
by YangZili
grinding the excess shape of the frame.
Klaster_1
by Klaster_1
@YangZili did I say that I like your thread yet? I love your thread.
YangZili
by YangZili
Drilling.....
