Project-X...first time build... 7.8kg
grahus
by grahus
FD Clamp
Front Derailleur
Cranks...
Bottom Bracket
Left Crank arm
Right Crank arm and spider
DS Crank Bolt
34t ring
50t ring
Rotor chainring bolts
And some ancillary parts...
Barrel Adjusters
Inner Brake cables - 22g
Outer Brake Housing - 67g
Inner Gear Cables - 27g
Outer Gear Housing - 44g
Bottle Cage - 33g
Cage Ti Bolts - 2.5g
Bikes:
Road: Project-X Pro Carbon (7.2kg) | Bianchi via Narone (bare metal project)
MTB: Canyon Spectral 6.0 Ex 27.5" | GT Zaskar 26" | Orange Clockwork 26" (Limited Edition green)
grahus
by grahus
Brakes...
Front Brake
Rear Brake
And I forgot these when I weighed the brakes...
Brake Cable Clamps
Bikes:
grahus
by grahus
More....
Chain catcher
Bar Tape
Bar Plugs
Pedals
Bikes:
grahus
by grahus
Where I am at...
Pics of the build as it is now, with Build List and weights...
As built...
Still got some reductions to make...
Bikes:
grahus
by grahus
New on this upgrade were;
ROTOR 3D30 crankset with noQ 50/34t rings - This saved very little weight but I preferred the look over the 105 crank it replaced. Shifting on the Rotor crank has been faultless (-37g from 105). I was surprised at how light the rings are too.
Rotor BB (BSA) – had to change this for the crank, slight weight gain over the Shimano stock item (+14g over 105)
Front Derailleur – Dura Ace 9000, good performance as expected (-22g from 105)
Rear Derailleur – Dura Ace 9000, perfect shifting as expected, alloy pulley/guide wheels installed as the black plastic ones are boring (-61g from 105)
Fourier BR-S003 brakes – only single pivot, but found them easy to setup and the stopping power on the stock pads is fine. Actually quite impressed with these, good price vs. reduction in weight (-140g from 105)
Saddle – Ultralight carbon saddle from China, and reasonably comfortable considering it is unpadded (-134 over Selle Italia)
Seatpost – Hylix Inline (stock cradle/bolts), does the job, still need to cut off approximately 80mm from the bottom (-80 from Fizik R5)
So 460g saved with plenty more scope remaining…
Bikes:
