Crumpton: Round #2
stax
by stax
Maybe you could try a couple of layers of duct tape?
glepore
by glepore
Hah. We need photos.
Actually, you could jb weld the crack (put tape or plasic wrap on inside first) and see if that quiets it. You were going to fix it anyway if the geo worked. The frame is worth 750 with the click. I'm not trying to bust on you, it just that this was what, the cost of half a Jetta when new?
I'm amazed at used bike values. A nice SL in a similar size with newish etap, exalilth Kry's and a $300 saddle just sold on ebay for a little over 3k. You could part the bike and keep the frame for under 500 bucks.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
fa63
by fa63
FiberFix that bad boy :D
https://youtu.be/haPvuhznuyI
glepore
by glepore
I was posting while drinking (Lost Abbey 10 Commandments, yum) but I was serious about jb weld or epoxy in the crack. I wouldn't consider it a permanent repair, but it could help determine the source of the noise, and won't make a permanent repair, if needed, any more difficult.
nicrump
by nicrump
glepore wrote:
Wed Mar 21, 2018 3:53 pm
Please do not do that or the duck tape. both will impede a repair by me.
Duck tape when removed can seriously cause un-needed delams from the crack when removed
JB wont do andything to remedy the crack but just make more work for me if he chooses to send in for repair.
RyanH
by RyanH
Thanks Nick, I can only hope they were kidding. The frame will most likely be coming your way as a frame as beautiful as this deserves to be repaired and done correctly, I just want to make sure I can track down the source of the noise before I send it, in case it's being cause by another area that may need to be addressed.
RyanH
by RyanH
Fingers crossed, I think I resolved the creak. I'll know after tomorrow once I get a full ride in but riding around my street I couldn't get it to happen. I swapped the THM crank and BB for my SRAM Red crank and delrin bb. The THM NDS side was a bitch to unscrew but that DS tapped out pretty easily so it's possible I didn't get good adhesion of loctitie 609 on that side.
stax
by stax
RyanH wrote:
Fri Mar 23, 2018 7:30 pm
Well, nope, I wasn’t kidding- just trying to help you find that annoying noise and elimanate possibilities. I didn’t think about delamination of the carbon, but did immediately think that something as simple as cling film could be a barrier between the carbon and tape when nicrump chimed in with no helpful solution. This may or may not have worked but the dismissive replies were unnecessary. But hey, this is the internet...
nicrump
by nicrump
i somehow just recalled why i left these forums years ago...
glepore
by glepore
Yeah, I have to say that I was obviously wrong, and Nick was kind enough to step in with real knowledge. I just assumed, wrongly, that a temp repair would be easily removed with a dremel and a cutting bit. My bad. Nick, thanks for stepping in.
mrfish
by mrfish
Nice that we have a manufacturer a) helping with an "old" product b) taking time to write here. You're on my good guys list Nic!
RyanH
by RyanH
Since I'm about to ship this off to Nick (and I'm supposed to be working on a large project, so procrastinating made sense), I figured I'd take some detailed shots of the frame that hopefully captures Nick's craftsmanship:
Kumppa
by Kumppa
Getting also paint on it or just repairing? Seatstays looks pretty narrow, can you use 25mm tires on it?
spdntrxi
by spdntrxi
Dont paint it.... unless you can get camo with blue like the Z0 you want :)
