Specialized Allez E5 Smartweld Premium
pekruhnium
by pekruhnium
Updated pictures: 🙂
KCNC C7 brakes
Cero AR 24 evo
Michelin Lithion 3
2 bottle cages
FSA SLK handlebar
_
Still waiting for the kalloy uno stem and the carbon saddle and black chainring bolts.. It will take a month to arrive. :roll:
_
pekruhnium
by pekruhnium
Now with SRAM RED (2. gen) Shifters + front derraileur.
Sram force (2.gen) rear derraileur.
Now I'm waiting for a new seatpost, stem and saddle from aliexpress ..
pekruhnium
by pekruhnium
Hi’
I would like to change the chainset to a Sram bb30. Now the frame have the osbb alloy with 30to24mm adapter for hollowtech II.
Can I simply remove the shimano adapter and insert a bb30 Sram without new adapters?
Thanks! :D
vejnemojnen
by vejnemojnen
Get Campagnolo Comp Ultra OverTorque chainset from merlincycles.co.uk...
happyon2wheels
by happyon2wheels
pekruhnium wrote:
Thu Mar 29, 2018 9:57 pm
Thanks! :D
Yes, the'll come right out. It's basically just a plactic reducer inserted into the BB30 bearings, so pull them out and you should be ready to install the new crank.
vejnemojnen
by vejnemojnen
and I'd opt for lighter tyres.
https://www.ebay.com/itm/TUFO-Calibra-P ... Sw2GlXEKv4
https://www.ebay.com/itm/New-ZIPP-Tange ... SwstJZTJ5W
with latex tubes, or tubolite tubes (39 grams..)
pekruhnium
by pekruhnium
A nerdy and specific problem!
I have just got the 105 chainset of, and the 30 to 24mm adapters seem to have det bearings glued into them.
So I need to order new bearings..
I have also bought a Sram Force bb30 chainset. (10 speed)
Do I need spacers or wobble spacers, and/or do i need some kind of seal between the beaings and the sram chainset? :?: :shock:
CrankAddictsRich
by CrankAddictsRich
pekruhnium wrote:
Sat Mar 31, 2018 3:21 pm
Picture?
pekruhnium
by pekruhnium
I have now ordered the new bearings.
Does any of you know have many spacers/washers I need on a Allez Smartweld to install the Sram force cranks?
The bearing set is from BBB, and has only one washer with it. :noidea:
pekruhnium
by pekruhnium
pekruhnium
by pekruhnium
Now 7.2 kg
could save weight with lighter seatpost, lightweight tubes.
I'm satisfied. The bike cost 1200 dollars!
Great bike!
pekruhnium
by pekruhnium
Made it more stealth!
I only want to change the cables and rearbrake for a all-black look.
delete your twitter account
