2017 Cervelo S3 disc build
kavlares
by kavlares
let me elaborate...
Adding spacers to raise the stem/handlebar is a no no aesthetically... I'd have to use 25mm to get from 505 to 530 stack plus the 10 mm that I am using on my current set up, (a KUOTA KOM size small) for a total of 35mm... way too high for my taste... while on the reach front I just have to switch from a 100mm stem to a 90 mm and save the 9mm difference between frames...
Anyway if I ever get there I will post some pictures for you!!!
thanks
lewishong9
by lewishong9
have you had any rubbing issue with Roval's 29.4mm external rim width?
I'm thinking about purchasing cl50s for my s3 discs as well.
Connor
by Connor
In regard to the rat axles: the 2019 s3's will be coming with them. The 2018 and prior s3's used maxels. For now it is possible to switch the rat on the rear to something lighter by changing the rear derailleur hanger and in the future cervelo has said they will produce an insert to switch the front rat.
