2017 BMC SLR01 - 6.03 Kg (Cane Creek Aer Headset installed Pg 11)
CAMSHAFT
by CAMSHAFT
I had a leak this morning with the Tubolitos. I went from 7 bar to 2 or so in 3 miles. I am not going to pass judgment until I do some more research. It was frustrating though...
spdntrxi
by spdntrxi
damn , dont they require special patches too ?
marek
by marek
CAMSHAFT wrote:
Fri Aug 03, 2018 3:07 pm
Must have been a bad luck. I'm using them since 3 months and no issues. You've punctured the tube or it was fabrication failure ?
They require special patches.
I confirm that they are 39 grams each (42mm valve).
billendk
by billendk
Have been using tubolito for 2 month. Get a puncture and put on a tubolito patch. It works for 14 days and then it start leeking around the patch. Back to vredestein latex.
spdntrxi
by spdntrxi
billendk wrote:
Fri Aug 03, 2018 7:27 pm
real world use comments are greatly appreciated... thx
Klaster_1
by Klaster_1
One of mine leaks too, but way slower (70psi to 40 psi in a week), so I contacted the manufacturer and they replied with:
Tubolito wrote:You are totally right, such a fast deflation is not supposed to happen. As a first step I would kindly ask you to please screw the valve core a little more. Maybe this already helps avoiding the pressure loss.
If this doesn't help you, I'd email and share the results with others.
CAMSHAFT
by CAMSHAFT
I determined the leak was a pin prick size hole. I do not know what caused it. I am attempting a patch.
CAMSHAFT
by CAMSHAFT
I installed the AER headset (upper and lower). First off this craftmanship is excellent. Their stuff is top notch. I take pride that they are from my home state of North Carolina.
Note: I did not use the bolt, expander or cap.
CAMSHAFT
by CAMSHAFT
I fixed the hole in the Tubolito. I used a Park Tool Super Patch. Its kept air for 7 hours now.
shoon
by shoon
I believe changing your rotor qarbon chainrings to carbon-ti oval ones will reduce weight further.
Also since you have a 50-34 compact crankset, why not use the xg1190 11-25? Don't think you will need a 11-32T (which is heavier) on that compact crankset
bilwit
by bilwit
the corsas are pretty heavy too but the ride quality and cool aesthetic might be worth it :P
spdntrxi
by spdntrxi
op is colorado.. might explain the 11-32
CAMSHAFT
by CAMSHAFT
shoon wrote:
Mon Aug 06, 2018 10:15 am
I would love to try the Carbon-Ti however, I am tied to the SRM power meter. I dont believe they would work with the SRM spider.
As for the 11-25, I live in CO. I can't go too far from the house without going up a hill/mountain.
CAMSHAFT
by CAMSHAFT
bilwit wrote:
Mon Aug 06, 2018 5:09 pm
True statement! :D
