2017 BMC SLR01 - 6.03 Kg (Cane Creek Aer Headset installed Pg 11)
CAMSHAFT
by CAMSHAFT
So whats next? Help me out. Right now I am thinking the following areas can be lightened, some I know the products I want and some I dont know:
EE Brakes
Brake Cables - Powercordz or Alligator may do the trick. I had Aican in the past and didnt like how they held up.
Rotor Qarbon Rings - Having some type of asymetric chainring is a must. I am a huge fan. Also I bought a SRM Power Meter, so I'm stuck with the Rotor crank.
Notice the photo on the page... http://rotorbike.com/catalog/default/ro ... 10bcd.html
11-32 Casette - Recon may be the way to go.
Bartape - I have some Lizards Skins and Deda Traforato that seem to be pretty light
Wheels - I am a fan of the 25mm width of my Hed. The new wheels would have to be just as wide.
Thoughts?
Lewn777
by Lewn777
Brakes: EE brakes, if I could afford them I would, otherwise Dura Ace.
Cables: Powercordz. Tried them but didn't like the brake feel, too 'springy' in modulation, scary as they are so weak laterally. Maybe just powercordz for shifting?
Cassette: 11-32 is good, but I often spin out with 50-11 (depends on your roads). I would go with 53-36 and an 11-32, but it depends on your weight fitness and grade percentages. I struggle over 20% gradients with a 34 and 11-28.
Bartape: Go with what your like and don't worry about the weight, there's hardly any saving.
CAMSHAFT
by CAMSHAFT
Lewn777 wrote:
Sun Apr 15, 2018 2:03 pm
Thank you for your reply.
- Its an Etap bike so I only need brake cables. Thanks for the advice, I dont want springy modulation.
- I live in Colorado. The Rocky Mountains are no joke. 11-28 with 50/34 is adequated. This is the first season trying 11-32. Well see how it goes.
rossjm11
by rossjm11
I run powercordz on my SLR01 and I completely disagree with @Lewn777. Only brake housing I've found to work well with the front end of the SLR01.
BMC SLR01 2015
Redline Conquest Team
CAMSHAFT
by CAMSHAFT
rossjm11 wrote:
Sun Apr 15, 2018 10:47 pm
So the modulation is tight and responsive? What brakes do you use?
CAMSHAFT
by CAMSHAFT
Today I went shopping for a few items:
- Rotor Qarbon chain ring.
- 2x M5X40 Schmolke Bolts
- M5X35 and M5X40 Titanium Bolts
The bolts are for the saddle clamp.
Also I am contact with @Berk for a possible custom carbon saddle clamp. He would have to shave off a few grams from the current 59 grams. Hopefully it isnt too expensive.
Alex2012
by Alex2012
CAMSHAFT wrote:
Tue Apr 17, 2018 7:53 pm
I'd be interested in a Berk solution also if you need to meet a volume requirement, assuming the price and weight saving was reasonable of course.
CAMSHAFT
by CAMSHAFT
Alex2012 wrote:
Wed Apr 18, 2018 7:48 am
I'll post here when I know more.
CrankAddictsRich
by CrankAddictsRich
CAMSHAFT wrote:
Mon Apr 02, 2018 3:52 am
An out and about pic with the iPhone.
That is a great looking bike... I've always wanted to pick up a set of Ardennes or Belgiums to use for winter wheels.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
2017 Specialized S-Works Tarmac SL5
2015 Specialized S-Works Allez
2014 Specialized S-Works Shiv TT
2015 Specialized Venge Pro (Retired)
CAMSHAFT
by CAMSHAFT
CrankAddictsRich wrote:
Wed Apr 18, 2018 11:59 am
Thanks!! I highly recommend them. The width is one of the biggest reasons why I went with them. With 25c tires it ballons out huge. The handling is great!
rossjm11
by rossjm11
CAMSHAFT wrote:
Mon Apr 16, 2018 2:04 am
Dura Ace brakes, and really with powercordz, it is the first time I have had good rear braking without ruining cables up front running into the frame. When team BMC was using 2105 SLR01s, they had powercordz for the rear brake.
http://www.cyclingnews.com/news/tejay-v ... de-france/
As you can see in this link!
BMC SLR01 2015
CAMSHAFT
by CAMSHAFT
rossjm11 wrote:
Sun Apr 29, 2018 5:59 pm
Ok I am a believer. They are my next purchase.
CAMSHAFT
by CAMSHAFT
I picked up a few items. A few more are on their way.
Ti Seat bolts (4 grams reduced)
Qarbon Chain Ring (23 grams reduced)
CAMSHAFT
by CAMSHAFT
A new bar and stem dropped on.
I found an AX Lightness setup on eBay
I like the clamp much better than the Zipp stem
Not only did it save weight part for part but, the stem is taller on the tube so it negated the top spacer.
All said and done it only removed 0.09 Kilos. I didnt expect that much to come off since the Zipp combo is already super light.
CAMSHAFT
by CAMSHAFT
FSE Extralite Wheels arrived today. I went and picked them up at the Post Office. Fit and finish looks good. They feel lighter than my Ardennes. More to follow as I install the veloplugs (hopefully they fit) as well as wheels/tubes.
