2017 BMC SLR01 - 6.03 Kg (Cane Creek Aer Headset installed Pg 11)
CAMSHAFT
by CAMSHAFT
JScycle wrote:
Mon Jul 30, 2018 5:17 am
CAMSHAFT wrote:
Mon Jul 30, 2018 2:47 am
the minimum is at the 10mm mark
Are you sure you don't mean the 10cm mark?
The red 10 in my pic.
CAMSHAFT
by CAMSHAFT
ghisallo2003 wrote:
Mon Jul 30, 2018 4:57 pm
I think you mean 80mm rather than 8mm.
If you are really chasing the grammes then it is a weight loss with no impact on function.
80mm
JScycle
by JScycle
CAMSHAFT wrote:
Tue Jul 31, 2018 2:05 am
That red 10 means 10cm or 100mm from the blue tape you have put on it
spdntrxi
by spdntrxi
think... measure twice.. think then cut. I kinda get the inkling the op is not comfortable.. so my vote is to leave as is.
CAMSHAFT
by CAMSHAFT
spdntrxi wrote:
Tue Jul 31, 2018 3:35 am
Im comfortable with cutting just not the permanance of cutting the post. I am worried about removing any future flexibility.
CAMSHAFT
by CAMSHAFT
AER headset ordered!! Once the Tubolito and AER are put on we should be below 6 Kilos!
CAMSHAFT
by CAMSHAFT
I went safe with 60mm. I saved 16 grams.
CAMSHAFT
by CAMSHAFT
The Tubolitos came in quick! High marks for shipping!
The valve is much longer so easily accesible and looks cool.
Between the 16 grams lost from the seatpost cut and Tubolitos we lost 50ish more grams. 6 Kilos is around the corner!!
Klaster_1
by Klaster_1
CAMSHAFT wrote:
Thu Aug 02, 2018 3:00 am
Did you replace RD jockey wheels yet? What about seatpost yokes and bolts?
CAMSHAFT
by CAMSHAFT
No and just the bolts. Do you know where I can get some lighter yokes?
Klaster_1
by Klaster_1
CAMSHAFT wrote:
Thu Aug 02, 2018 12:43 pm
I had luck with POP-style yokes on eBay, Schmolke sells seatpost spares too. Maybe ask Darimo about yokes from T2 seatpost. Both of designs have it's own pros/cons compared to a single top plate if that's what BMC uses. Cradles are more tricky because you have to match the diameter and possibly depth. But first of all, I'd weight all the seatpost parts to be sure you'll benefit from this level of tuning.
JerryLook
by JerryLook
How do the Tubolito tubes ride compared to normal butyl tubes? Or compared to latex tubes if you have experience with those.
I had never heard of them before seeing your thread. Just curious about rolling resistance etc
2010 Orbea Opal 54cm
6.4kg
Klaster_1
by Klaster_1
JerryLook wrote:
Thu Aug 02, 2018 4:05 pm
I roll on Tubolitos too and did not notice any difference at all compared to Pro Ones. Here are RR graphs from FAQ section of Tubolito website:
JerryLook
by JerryLook
Very interesting. Looks like these are very close to latex as far as rolling resistance. And quite a bit lighter too. Good to know.
Thanks for posting the graphs.
6.4kg
dereksmalls
by dereksmalls
What is the weight of those Turbolitos, I cannot make it out fromthe scale shot I'm sorry.
