2017 BMC SLR01 - 6.03 Kg (Cane Creek Aer Headset installed Pg 11)
CAMSHAFT
by CAMSHAFT
I just checked the Cane Creek site and they updated their compatitbility identifier. They do make an AER set that fits.
CAMSHAFT
by CAMSHAFT
One problem though. I have a creaky bottom bracket with Rotor BB. I want to try the BB Infinite. Supposedly it removes the creak. I will probably add some weight. Hopefully with these recommendations I will drop low enough to offset the gain.
https://www.bbinfinite.com/products/cop ... 1066005563
ED76
by ED76
Tubolino inner tubes: 39gr.
CAMSHAFT
by CAMSHAFT
ED76 wrote:Tubolino inner tubes: 39gr.
I checked them out, I’ve seen a few like them. I keep forgetting to try them out!
DartanianX
by DartanianX
CAMSHAFT wrote:I have not. It has gone through my head though. I am concerned with possible resale. What is the rule of thumb for leaving length?
Generally, just measure the existing minimum insertion mark and replicate that. In theory, as you are running a lower saddle height you could reduce this even more as there is less post exposed = less leverage
I’ve done this on all my bikes bar my Emonda SLR.
CAMSHAFT
by CAMSHAFT
DartanianX wrote:
Mon Jul 23, 2018 4:31 am
Cool, thanks!
CAMSHAFT
by CAMSHAFT
Tubolito Tubes ordered. They are coming from Austria so hopefully they come quick...
AER headset will be ordered on the first.
CAMSHAFT
by CAMSHAFT
Right now cutting the seatpost is going through my mind however, I dont want to cut too much. Decisions, decisions, decisions.
CAMSHAFT
by CAMSHAFT
So based on @dartanianX's advice I can kill about 8mm off of the seat post. Note: the minimum is at the 10mm mark. Any thoughts?
spdntrxi
by spdntrxi
lop half.. 10mm min seems low
DartanianX
by DartanianX
I’d cut 80mm below where your saddle clamps. That’s more than what’s needed.
JScycle
by JScycle
CAMSHAFT wrote:
Mon Jul 30, 2018 2:47 am
Are you sure you don't mean the 10cm mark?
JScycle
by JScycle
JScycle wrote:
Mon Jul 30, 2018 5:17 am
If you are going to cut 8mm it's not worth it. That's voiding your warranty for approximately 5-10grams
spdntrxi
by spdntrxi
probably not worth it in the long run... I'd search somewhere else for the gramz
ghisallo2003
by ghisallo2003
I think you mean 80mm rather than 8mm.
If you are really chasing the grammes then it is a weight loss with no impact on function.
