2017 BMC SLR01 - 6.03 Kg (Cane Creek Aer Headset installed Pg 11)
CAMSHAFT
by CAMSHAFT
Long time lurker, then poster, then I found a new hobby, now I am back.
Soooo I crashed the 2013 SLR01. In its last configuration with SRAM Red it was around 6 Kilos. Later I pulled the Red off and put it on my Cervelo S5. The SLR01 Frame sat for about two years and was reborn with the Ultegra Group from the S5 about 6 months ago. Within a short time of its rebirth I accidently crashed it into the ditch. I contacted BMC and they are crash replacing it with a 2017 SLR01 Frame-set which should be here in a week or so.
I plan on using some similar parts but more than likely it will have its own flair. Right now I have allot things going through my mind. Do I ditch the Ultegra Group and go with SRAM E-tap or Mechanical, source some sick wheels, or pick up another power meter. I am not made of money so I do have a budget. Over the next few weeks those decisions will be made. Below is the place holder for the build thread for the shenanigans that will follow. It will be interesting to see how it all turns out in comparison to the 2013 model. One note though, while I am a weight weenie, the roads are super rough in Aurora, CO. That being said comfort is a goal too.
_________________________
Brand:.... BMC
Final weight:.... 6.7 kg.
SLR01 54cm Frame
Stock Fork
Stock Hanger
Stock Headset
Point One Racing Nano Second 5mm Spacer
Parts of Passion Carbon Top
Extralite Ultrastar 2 Expander
Stock Seatpost clamp
Stock Seatpost
Shimano Pro Steath Carbon Saddle
Zipp SL Speed 100mm Stem
Zipp SL Speed 40cm Bar
Specialized Bartape
Zipp Bottle Cages and KCNC Bolts
SRAM Cables
SRAM Red Brakes
SRAM Red eTap Front Derailleur
SRAM Red eTap Rear Derailleur
Rotor 170mm Crankset
Rotor BB86 Bottom Bracket
Rotor Q-Rings Chainrings (52-34)
KCNC Chainring Bolts
SRM Powermeter
KMC X11SL Chain
SRAM Red eTap Shifters
KCNC Titanium Road Skewers
SRAM 1170 11-32 Cassette
Hed Ardennes Plus SL Wheels
Vittoria Latex Innertubes
Vittoria Corsa Tires
Speedplay Zero Ti Pedals w/ Left 91.8mm TitaniumSpindles.com
Elemnt Bolt Aero Computer Mount
CAMSHAFT
by CAMSHAFT
The first weight is a good starting point. Look for another pound to drop. So far she feels great!
rossjm11
by rossjm11
For some reason this one is begging for some 80s, looks good!
BMC SLR01 2015
Redline Conquest Team
CAMSHAFT
by CAMSHAFT
I have a set of Jet 6/9. When I get a chance I’ll set them up.
Geoff
by Geoff
Ok, that's nice, too. I love the matt red colour.
Kazyole
by Kazyole
Love a good Teammachine. That color is great too. Not enough matte red bikes out there.
14lbs, 9 oz is 6.6kg though, no?
CAMSHAFT
by CAMSHAFT
Good catch. Corrected.
CAMSHAFT
by CAMSHAFT
SRM Powermeter installed and ready. They ran a sale on spiders that I couldnt pass up.
rossjm11
by rossjm11
CAMSHAFT wrote:
Wed Mar 07, 2018 3:37 am
what size Q ring is that? I couldn't get them to work with the braze on height of my SLR01..
BMC SLR01 2015
CAMSHAFT
by CAMSHAFT
52T. It works fine for me.
Geoff
by Geoff
Good choice on the PowerMeter.
CAMSHAFT
by CAMSHAFT
Thank you Sir!
CAMSHAFT
by CAMSHAFT
Swapped out the Open Corsa Evo CX for Corsa. I also went with Vittoria Latex. I have some Veloplugs (Red and Yellow) on order but, I dont think they will fit. If they dont fit I will try some Velox tape.
CAMSHAFT
by CAMSHAFT
An out and about pic with the iPhone.
CAMSHAFT
by CAMSHAFT
Completed a Veloplugs install. It wasnt that easy. I bought yellow and red plugs, with neither fitting. The best way was to make the yellow plugs smaller. I had to trim all 36 plugs with an exacto knife. All in all the tape I had on there was light. After completing the install the big scale didnt even display the difference. With the small scale I estimate a 20g difference but, hey im weight weenies and every gram counts.
These wheels are amazing already with Corsa over Latex.
Tape from the front wheel.
18 plugs
In progress pic.
