Colnago C64 - Inside and Out
edorwart
by edorwart
I use this and it works fine. But I have 0 spacers under my stem.
https://canecreek.com/product/eenut-preload-assembly/
hgw20
by hgw20
edorwart wrote:I use this and it works fine. But I have 0 spacers under my stem.
Quite similar to the extralite one. Im neither using spacers below the stem...
Enviado desde mi SM-N975F mediante Tapatalk
hgw20
by hgw20
Last question,.I'm wondering which Bottom bracket should I need to install a thm clavicula crankset.
Do your junk that the typical Rotor 4130 will do the thing right?
edorwart
by edorwart
I have the Colnago Ceramic Speed 30mm bottom bracket. It took a little extra figuring on the spacers to get the crank installed just right in relation to the chain line, bearing freeplay but it can be done. One issue is that standard 30mm axle spacers do not work correctly on non-drive side as the axel is tapered and that a sleeve that goes between axle and inner bearing race.
mikebuf73
by mikebuf73
Hi guys. I hope this is the appropriate thread (as opposed to starting another). Just received my long awaited frame set and am getting to work on the build. A lack of expertise, combined with a determination to enjoy the process, will surely see this build not break any time records but that's ok. I hope to have it done by weekend if possible...
I am just fitting the fork and have noticed that the headset cap/cover has a big gap in between it and the top of the head tube. I have pushed the 'inner grommet' (I'm unsure of its proper name, but it is the semi-soft plastic inner cap) as far as seems proper into the bearings but the gap is still very obvious. It may well be I need to put the expander bolt in and tighten in order to 'pull' everything together tightly? But I want to avoid manhandling things if I am making an obvious error at this point. Any advice greatly appreciated. Thanks.
edorwart
by edorwart
That gap is too big. Mine was kind of like that until everyting was tightened up as the soft plastic inner piece fits tight and will hold things up. Just make sure it is all lined up and nothng crooked and when you tighten down expander is should close up the gap
mikebuf73
by mikebuf73
thanks Edorwart
mikebuf73
by mikebuf73
Thanks Edowart
Fitted the BB yesterday - it was painful. Unsure about the choice of C Bear now, both in terms of fitting experience but more so due to pretty dire support/response.
Anyhow, it is in now but I wanted to ask for views on the pics below - when I pushed the crank through the dust cover on the non-drive side popped off. I’m not sure how much of an issue this is (or if it is at all) but wanted to check given this is all brand new stuff and the last thing I want is to have to pull everything apart again in the near future after toiling away at the build for the past days. I gently pressed the dust cover back into place with the BB press and it seemed to sit flush again (albeit I haven’t tried to pull at it to check how firm the seating is). Any tips? I think I read somewhere that putting a film of grease around the dust cover can help keep out any unwanted crap in such instances.
Thanks
Mike
MrMojo
by MrMojo
The cover on my Ceramic Speed bottom bracket did exactly the same, i just clipped it back in again and all good.
2020 Colnago C64 Mapei
2018 Cipollini NK1K
2017 Colnago C60
2017 Colnago V1-R
2014 Cipollini RB1K
2008 Colnago Extreme C
2005 Colnago C50
2001 Colnago C40 Mapei
robbosmans
by robbosmans
Yeah this can happen when fitting cranks, not unusual
Verzonden vanaf mijn iPhone met Tapatalk
mikebuf73
by mikebuf73
robbosmans wrote:Yeah this can happen when fitting cranks, not unusual
Thanks mate. Reassuring to hear. I smeared a little grease around the outside of the cover to give a little more moisture protection so hopefully all good.
Mike
mikebuf73
by mikebuf73
MrMojo wrote:The cover on my Ceramic Speed bottom bracket did exactly the same, i just clipped it back in again and all good.
Thanks Mr Mojo. Hopefully my pressing the cover back on with the BB press will have the same effect
Mike
hannawald
by hannawald
Hi all, does anybody know how much the original Colnago cups weight?
Trying to compare how much the combination of original cups + pressfit bb weights compared to Ceramicspeed solution (84g).
Thank you.
MrMojo
by MrMojo
hannawald wrote:
Mon Jul 27, 2020 7:31 pm
Trying to compare how much the combination of original cups + pressfit bb weights compared to Ceramicspeed solution (84g). Thank you.
28g for the pair
2018 Cipollini NK1K
2017 Colnago C60
2017 Colnago V1-R
2014 Cipollini RB1K
2005 Colnago C50
hannawald
by hannawald
MrMojo wrote:
Mon Jul 27, 2020 8:51 pm
28g for the pair
Thank you. As shimano standard BB92 is like 55g, its basically the same weight just to put there cheap shimano dura ace press fit bb instead of ceramic speed..
Does ceramic speed have any other advantage (besides highly discussed advantage of ceramic ball bearings)? I mean is it better for maintance/durability/no creeking to screw there ceramic speed or Colnago cups with Shimano press fit bb is similar reliability?
Thanks so much!
