New Wilier cento10air disc
wispawel
by wispawel
Hi ALL. My name is Pawel I'm 175cm . I'm looking to replace my current Giant TCX 54cm for Wilier Cento10air disc 52cm . I'm a bit concern if wilier will be ok or too small ? grabbing all frames dimension wilier have shorter TT but longer reach than Giant .
Is anyone have this bike in 52cm frame and similar height ??
Thanks guys .
TonyM
by TonyM
Do you want to replicate the somehow relaxed position of your Giant or do you want to have a more race oriented position? Depending in that you should choose the size of the frame (top tube and head tube) and the size of the stem (reach if the frame)
wispawel
by wispawel
Thanks guys for reply .
Giant dimension Wilier- small medium both of the wilier came with integrated stem either 90/400 or 100/420
TT - 545mm 526mm 541mm
Reach - 375mm 382mm 387mm
Stack - 556mm 519mm 536mm
giant stem 110/420 and I feel a bit stretched on it
Currently I'm at the lowest point with the stem on my TCX and I prefer more aggressive position , just cannot imagine how different it'll be if i choose small frame.?
Im thinking to get fit in bike fit shop , what should give me an answer .
TonyM
by TonyM
Yes get a good (!) bike fit and decide how aggressive you want to go or you can go.
wispawel
by wispawel
Thanks all .
Ill keep updated how it goes .
jimaizumi
by jimaizumi
If it helps, you're not relegated to buying the fixed Albarda stem/bar combo mated to that particular frame you're looking at. My size was a M with a 100x42, but was given the option of choosing any of the bars they offered. This should help in the fitting process as well.
THE PAST: 2005 C'dale R700, 2006 Spesh S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato, Cinelli Gazetta
THE FUTURE: :mrgreen: :mrgreen:
wispawel
by wispawel
Hi guys
Swift Cycles did great job with fitting , spent 2h and learned so much about fitting.
Results -
Medium frame with 120 stem . Surprisingly !
TonyM
by TonyM
More agressive position than on your Giant?
wispawel
by wispawel
No more agresive , but I can still slam it so it'll be more agresive .
Wilier coming mid Apr ( can't wait for it ) I'll post some pictures .
