2018 Scott Addict RC Premium disc-5.87kg
KaneChang
by KaneChang
Hello everyone, this is my first post & first road bike, this bike maybe no lightweight type, because it’s a disc brake road bike... :lol:
But it’s my first road bike, so I looking for many informations to save weight, hope can build a lightweight disc brake bike. finally I choose a 2018 SCOTT Addict RC Premium Disc, it’s a light & strong frame, and looking good 8)
Hope you like my bike, enjoy :beerchug:
PS: I will still update :up:
2018-01-27 updated
Build list are upload :smartass:
2018-01-20 updated
Finally finished this bike, but THM crank out of stock in our distributor, so I used Red 22 GXP, without pedal is 5.87kg, with pedal is 6.01kg(Speedplay Zero Nanogram), if upgrade THM can be save 100g.
crux
by crux
I like that frame a lot and I'm looking forward to this build :)
KaneChang
by KaneChang
I have the assembly & maintenance MTB bike experience, and got the almost necessary tools, I enjoy this process and assembly in my home, it’s funny :wink:
Addict weight test:
frame (S size with hanger)
fork (uncut)
KaneChang
by KaneChang
crux wrote:
Wed Jan 10, 2018 7:50 am
Thanks :beerchug:
Squashednuts
by Squashednuts
Hey,
Check out The build by Delorre
He's got the weight down to about 6.5kg
They're are really great looking bikes.
viewtopic.php?f=10&t=148680
Fuji SL 5.5kg tubs/5.9kg viewtopic.php?f=10&t=157704
Sold -
Focus Izalco Max Disc - Final Weight 6.7kg - http://weightweenies.starbike.com/forum ... o+Max+disc
KaneChang
by KaneChang
Squashednuts wrote:
Wed Jan 10, 2018 9:27 am
Hey,
WOW, awesome build :thumbup:
“They're are really great looking bikes.”——Agree :beerchug:
KaneChang
by KaneChang
I choosed SRAM eTap HRD to build, it may not a lightweight choose, but it look neat and clean :thumbup:
RD weight (Short cage and update Enduro pulley with Carbon-Ti alu bolt, it save 6g)
oem pulley wheel weight
Enduro ZERO pulley wheel weight
FD weight
KaneChang
by KaneChang
The hydraulic brake is best choose, so I upgrade a HRD shift-brake control to my eTap group set.
Actually, at first I want to use cable actuated hydraulic caiper to match eTap shifter, but HRD will more complete and light.
Front shifter with caliper (inc. steel pad & adapter & bolts)
Rear shifter with caliper (inc. steel pad & adapter & bolts)
Original steel brake pad
KaneChang
by KaneChang
MCFK35 Clincher+Extralite+SAPIM CX-RAY
F+R=1221g
Delorre
by Delorre
Stunning build and dito weight!! Do you have a complete build list? Intrested especially in the smaller parts like seatpost clamp, rotors, tyre setup,... Only thing that freaks me out, is the look of those chainrings. There seems to be almost no material to them. How is the shifting? Even with complete bone stock setup, etap perfect front shifting is not easy to achieve. I can imagine the patience needed to do it right with those rings :shock:
Can the wheels be de-stickered? There is a little too much white in it, and almost no with elsewere on the bike :|
What did you use instead of the stock alu part intended for shift cable entry at the headtube? Can you post a close-up pic?
mrlobber
by mrlobber
Great weight for a disc bike! :thumbup: :thumbup: :thumbup:
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
KaneChang
by KaneChang
Delorre wrote:
Sat Jan 20, 2018 4:44 pm
The chainring is Extralite, it perfect work with eTap front derailleur, shifting is good.
Mcfk no make a black decals, so I cannot do anything in this moment...
Headtube plug is a plastic, it not a bike parts, stock alu plug is not a good match with eTap.
Complete build list I will upload soon. :up:
mrlobber wrote:
Sat Jan 20, 2018 4:58 pm
Thanks so much :beerchug:
spartan
by spartan
nice build what type or rotors are these? weight? assuming you are using bolt on thru axles.
Current Rides:
2018 Madone SLR DISC DI2 9XXX
2017 Giant TCR Advanced SL 0 DI2 9150
dgasmd
by dgasmd
Write down a list of all components and parts used please. Weight of each in the same list would be awesome. Very nice bike btw. Some lighter tubulars wheels/tires and pedals would bring the weight down considerably too.
DOUG
by DOUG
Wowzer very nice build, puts my Supersix disc to shame!
I have the same wheelset on my build and if you remove the stickers you can save yourself 20g which would bring this under 6kg, plus I wasn't a fan of the stickers anyway so it's win win!
Sent from my Pixel 2 using Tapatalk
